LED Turn Signals - Relay
Old 04-25-19, 11:07 AM
bumbletuna
bumbletuna's Avatar
Originally Posted by Napalvr
Anyone try these? 50W 6 ohm 9-14VDC 16 gauge.
I am selling mine from iJDM toy. I bought 2 pairs and am selling one. They work great and are super bright.
Old 04-25-19, 11:22 AM
ex00
ex00's Avatar
You don't need the iJDMtoy versions since they just released new ones with built-in resistors without those spliced resistors they did. You don't have to worry about mounting the resistors. Aliexpress search: 7443 no hyper flash canbus
You will find them under $20 a pair with either white or yellow colors, free shipping as well. iJDMtoy is also selling the same versions for around $30 I believe. Not too sure on the warranty terms by them but Aliexpress usually has a 1 year warranty. I was able to get a 2 year warranty on mines by bulk buying them for some people.
Old 04-25-19, 12:39 PM
Napalvr
Napalvr's Avatar
I want all 4 bulbs changed out. Don’t I need resistors for all 4?
Old 04-25-19, 12:54 PM
ex00
ex00's Avatar
Nope. Thats what makes these new types so much better. They have the resistors built-in and it's the same size as a 7443 LED bulb just the electronics have them built-in(as what it should have been designed in the first place). So there isn't a need to mount resistors and splice wiring. Eventually we will see these "no hyperflash and canbus" turn signals appear on a lot of LED sites.
Old 04-25-19, 01:00 PM
Napalvr
Napalvr's Avatar
Plus I thought our original bulb was 7440 not 7443
Old 04-25-19, 01:04 PM
ex00
ex00's Avatar
They have it for the 744X series of bulbs. You can order a set of 7440 and a set of 7443 bulbs. But 7443 can replace 7440 but 7440 cannot replace 7443.
Old 04-25-19, 01:07 PM
Napalvr
Napalvr's Avatar
So..get 2 sets of 7443....what brand name? I see most common is iJDM, not iJDMtoy
Old 04-25-19, 01:11 PM
ex00
ex00's Avatar
I forgot which bulb was a tad smaller in diameter but it's safer to get a pair of 7443 and a pair of 7440 for fitment.
iJDM is the brand I went with(no way related to iJDMtoy). Their stuff is good and is well worth the price.
Old 04-25-19, 01:13 PM
Napalvr
Napalvr's Avatar
Does it matter which bulb goes in front or rear? Sorry for all the questions. You’ve been a great help
Old 04-25-19, 01:20 PM
ex00
ex00's Avatar
Yes. I believe the front is a 7443 bulb and rear is 7440.
The front is the smaller diameter from what I saw since I tried sticking the 7440 in and that couldn't go in versus 7443 should be able to clear the rear as well.
Old 04-25-19, 01:33 PM
ex00
ex00's Avatar
The 7440 is a clear bulb versus the 7443NA is a amber bulb from factory. They are pretty much the same bulbs just one is colored and one isn't. Actually 7440 has a NA version as well.
Someone should really start making bulbs standard and not just use what you feel like putting. It get's annoying when having to bring in 7443/3157/BAY15D bulbs for all types of cars. Same goes for T10(mini/standard) and festoon(29mm/31mm/etc...)
Old 04-25-19, 01:36 PM
Napalvr
Napalvr's Avatar
I can’t find the 7443 bulb in amber just switchbacks.
Old 04-25-19, 01:53 PM
Napalvr
Napalvr's Avatar
Never mind I found them. Thanks again
ex00
ex00's Avatar
7440 Bulbs
7443 Bulbs
Amber bulbs only. I don't suggest running out of DOT colors.
Old 04-25-19, 02:52 PM
Napalvr
Napalvr's Avatar
7440 Bulbs
7443 Bulbs
Yep those are the ones I ordered
Quick Reply: LED Turn Signals - Relay
