Unlocking car
Hello everyone,
I have a simple question. Whenever I unlock my door only the driver side unlocks, is there a quick fix to allow all the doors to unlock at the same time?
I can't find the specific documentation on it, but if you hold the lock button on your key fob until you hear an audible beep, and then touch the handle it should toggle over to the "unlock all doors" mode. Or it might be the unlock button until an audible beep happens.
Otherwise, if you have Nav it will be in your vehicle settings, and for non-nav in the steering wheel controlled settings.
Standard is pressing unlock once unlocks the driver door and pressing it twice unlocks all doors.
It could be a faulty lock motor in your doors? I had an issue when i went to open the drivers door, all the doors except the drivers would unlock, and I had to hop through the back to unlock the drivers door. After going through this issue for about 8-12 months (happened inconsistently), the dealer finally found out that the motor in the drivers door wasn't functioning properly and they replaced it for me under warranty. Haven't had a problem since.
arentz07 (05-16-17)
TommyT
08-24-13 12:03 PM
galletgun
IS - 1st Gen (2001-2005)
11-01-09 12:59 AM
BottomsUp
09-26-06 05:46 AM
