Need a good suggestion - tire
hello there. I recently put work vsxx wheel on my 2015 is350 f sport cause I got a good deal.
Front 19x9.5+40(R)
Rear 19x9.5+39(O)
so far the tire size is 235/40/18 all around but now I have to get new tires so I was wondering if I could have different tire of size for front and rear. My car is not lowered at all. I won't be lowering for a lot time so far so please give ma good suggestion and I would be getting Michelin sport tires all season
Front 19x9.5+40(R)
Rear 19x9.5+39(O)
Despite the offset of the wheels, they are the same size is terms of height and width.
Ideally you would want to use the same size tire all around.
A 265/35/18 will look good and give you a nice ride.
It would be hard to put different size tires front and rear since the rims are the same size...matching the circumference is almost impossible.
I would go with the 265/30/18 all around, but that's just me. If your IS is not AWD, you could chance the 255 and 265, I'm not sure if it would affect anything else like the ABS, VSC or TRAC.
The offset numbers seem odd for the pic...but I find those 3 piece wheel offsets odd in general.
Chances are there will be rubbing in the front at full lock turns.
I think you meant 255/35/18 and 265/35/18.
Looks like no one makes a 265/30/18.
The good news if it does rub it will be on the inside, so you could add spacers to fix that.
scarru
03-15-16 09:54 AM
