IS200t Transmission issue
It's not really a problem. Probably just something you notice only under very specific conditions. I put my car in drive and take off normally, it's perfect. But if you put it in drive at the same time as releasing the gas, I can see the jerk. It's likely normal, the transmission has to engage and move the car forward somehow. It's just usually masked by having the foot on the brake cause that's how you're supposed to take off like a normal person does. lol
Hi, I also own a 2017 is200t. I do experience quite a similar issue as you, but not as you mentioned the car jerk forward.
ok, what I experience is when I turn the ignition on, then shift the gear from parked mode to drive mode, I sense the car trying to move forward even though
i have the brake on.
Do you experience this issue after you switch the ignition on, then shift from parked to drive mode? Or you
experience this issue every time even when the engine is running?
I have a hunch and think its due to the car not being fully at operational temp. If I wait a minute or more, then this jerky action doesnt really happen. If Im in a rush and have to engage D a few moments after staring, then I get the jerky motion.
Hi, I have checked this issue with the dealer. He mentioned that is normal and it usually
happen when we first start our car in the morning. He also mentioned let the engine run a few mins
to warm it up before engaging the gear to drive.
Hope that helps.
Hope that helps.
Ive driven my IS for a year now and have never noticed this until you guys brought it up. I guess it just doesn't bother me as much as some of you here. I work for Lexus and while I drove the 16' 17' IS350, they have the same slight jerk when shifting from drive to park. Is this a serious problem or just nit-picking?
you answred your own question. You're shifting into gear before the RPM's have dropped to a normal level. That jerk is the torque converter catching up to the engine RPM. Wait for your cars idle to slow down before putting it in gear.
IS200TFOWL (07-14-17)
A few minutes? No. The 30 seconds, or so, that it takes for the RPM's to drop a bit? Yes.
letting car idle is actually bad for it (and the environment). funny how a lot of people (usually with reliable makes like Lexus/Toyota/Honda) think they're being extra caring to their car by letting it idle. 30seconds is starting to become abusive. I'd say no more than 5-10 seconds at most.
the longer you run that engine cold, the more wear/tear and pollutants (cat inefficiency). let the engine get some light load on it so it warms up fast and the cats and coolant get hot.
as far as the trans thing, just don't release the brake until the trans is fully engaged and its smooth as butter every time.
where are you getting your information from? Or are you being sarcastic?
drives cars
I usually wait about 10 seconds before I take off to allow the revs to drop, since I want the oil to have actually made its way mostly around the engine before I put any load on it. In the winter time, it takes just a few more seconds... Usually however long it takes me to clear the windshield of ice/snow.
However, the engine itself isn't the point of this discussion (and neither are cats, etc.). The jerk is possibly resulting from letting off the brake too quickly after shifting into R or D. If you have the brake fully depressed until you've changed gears, it should be smooth, just as E46CT stated. If you let the revs drop after a few seconds, this jerking effect will be lessened, but not eliminated
The jerk isn’t noticeable at all once the car is warm. I wonder if it could be an issue with low ATF? I also have a significant jerk when the torque converter locks up in manual mode shifting up/down into 3rd gear, which I am starting to think could be related
jdanielca
08-26-18 11:07 PM
Lavrishevo
10-20-13 02:38 PM
