spring dilemma
spring dilemma (pics post number 31)
hi all,
so i have a 2014 IS 250 that i want to drop. i have two options as i ordered (foolishly) both and they are the rs*r down springs and the oem f-sport lowering springs. i'm trying not to ruin my suspension and have to buy new shocks/struts within the next year or so and thus i want to know realistically these two options will fare with regard to suspension components. the rs*r down springs will give me more of what i'm looking for, although the f-sport springs won't void my factory/extended warranty should something down there need to be replaced as a direct cause of either of the two, although the rs*r down springs in particular.
the car is a non-f-sport, although it has the luxury package. is anyone here lowered using the oem f-sport springs? how large is the drop? i'm running 18" oem lexus g spider wheels.
any advice would be appreciated.
thank you!
edit: *pics on page 3, post 31*
thank you!
I have fsport springs. After installed, the rear is at 2 finger gap and maybe a little more at the front. The good thing with this set up is you will have max negative camber(-2.0). Therefor you may not need rear camber kit for tire wear.
davyjordi (07-09-17)
If you are worried about shocks getting blown, I would keep the F sport springs. There are people talking about blown shocks after installing RSR downs. Your shocks with F sport springs should be covered by warranty as long as it is installed by the dealership.
yeah, that's the route that i'm going to take. i don't think i'm going to have them installed at the dealership, though. they're asking 800$ to install the springs. i'd be better off at an indie shop.
i just received the f-sport lowering springs today and in the packet of papers that came with it it states that i must install f-sport shock absorbers at the same time. because the car these are going on is a non-f-sport, is there any real problem or potential problem installing with the factory shocks?
i'm having them installed tomorrow but want to know what i am getting into.
any insight would be appreciated!
Would like to see the before and after pics of the drop, and the funds you had to spend for this project.
I'm thinking of going the fsport spring route, for warranty reasons.
Received 1,737 Likes
I looked for myself when installing my RSR Downs, which drop the vehicle almost the same as the F Sport springs. Not sure if I didn't look hard enough or wasn't looking in the right places, but I couldn't find the F Sport shocks locally.
Presumably my stock shocks will go at some point, maybe by then I will find the F Sport shocks.
Personally...if I had the funds to support installing both the F Sport springs and shocks, I'd do it.
Non Fsport shocks have more dampening for a softer ride, so you'll likely get a lower drop vs fsport. However you won't be in warranty since those two parts are incompatible and your shocks will wear out faster. Usually, your car will be a bit bouncier than before.
F-sport shocks are stiffer, so the drop is not as low. You'll be in warranty and the car handles better. The con here is obviously the cost..
Just to confirm, the fsport springs will not affect the avs i the is350? right?
so, i had the springs put onto my car a few days ago and so far it hasn't "settled" at all -- it looks like the day i picked it up from the shop. i like the subtle rear drop, although the front leaves much to be desired; it looks like it's sitting at stock height. the slight negative rake bugs me. i know many say that the springs have to settle, although manufacturer info states in many cases that there isn't any settling when installing lowering springs. i don't know who makes the stock f-sport lowering springs and that may not matter anyhow. anyway, any tips aside from replacing the springs or am i stuck?
