Mirror cap removal
I had to do this to swap a mirror before. Take your time with it and don't try to do it as fast as the guy in the video does it lol (you def don't want to break a part off, especially in the assembly where the mirror clips into) Start off at the bottom left corner and work your way around.
I tilt mirror up (be gentle), take flat tip screwdriver (two if possible) to pry up under mirror where attaches. I believe there's two upper clips two bottom clips. Once you pry the mirror from the bottom ones, it'll come off. Sometimes with adhesive. Pull slow. Then carefully undo the heater element. Then the philips head screws will be exposed to remove the cap. It's a good time to also replace the Mirror Puddle Bulbs with bright white LEDs like I did. I used these:
http://amzn.to/2tMJMim
LEXuriouss
SC- 1st Gen (1992-2000)
01-22-07 12:46 AM
