Opened my sunroof and a trim piece fell off
Old 07-12-17, 10:43 AM
kneemahp
kneemahp's Avatar
Default Opened my sunroof and a trim piece fell off
It's hot out here and while most of us our still under warranty, you might want to open the sunroof and make sure the trim piece (accordion rubber seal) doesn't fall off like mine did. Dealership took care of it, but said it was caused by the heat wave we've been having here in los angeles.
Old 07-12-17, 11:24 AM
Darqhelmet
Darqhelmet's Avatar
Mine just did this yesterday. I need to call Lexus of Westminster and get it taken care of.
Old 07-12-17, 12:52 PM
nathantse
nathantse's Avatar
Been almost 2 years.. I have not open my sunroof. I sometimes forget its there.
I'll need to check on it.
Old 07-12-17, 12:55 PM
Darqhelmet
Darqhelmet's Avatar
Originally Posted by PatrixUSA
If you're a DIY person, that accordion piece is somewhat easy to re-apply, just need to find the grooves that match to re-insert.
See image linked here. In the image, the trim piece I had fall out (sounds like the same piece) is #3 - it simply needs to be slid into a groove on piece #9 in the image. Take a look, may save you a trip to the dealer as it's pretty easy to apply. Mine on one side was not inserted correctly and kept coming out - when I inserted it correctly, I've had no more issues with it. Good luck.
I have to go in for the rear wheel well corrosion recall anyways. Just adding it to the list. I shoved it back in the first time it happened, but it fell out again the next time I opened the sunroof and drove.
Old 07-12-17, 01:30 PM
39RN
39RN's Avatar
Happend to me too. But my piece actually split/ripped at where it connects to the sun roof. Dealer is taking care of it under warranty.
Old 07-13-17, 09:10 AM
davyjordi
davyjordi's Avatar
haha me either. I think I'll finally open it to see if the trim falls apart.
Old 07-13-17, 09:29 AM
isosunrise
isosunrise's Avatar
Mine came off a few days ago.
Old 07-13-17, 10:14 AM
fivesevenn
fivesevenn's Avatar
Easy to install back on the sunroof, takes 5 seconds. if not we can warranty at the dealer.
Old 09-17-18, 06:06 PM
tofuprod
tofuprod's Avatar
sorry to raise this from the dead, but the lady has had this happen twice already within 3 months on her '15, still under warranty.
However, my question is, is there a permanent fix to this? Also, if I were to remove these pieces, would it do anything for functionality? I highly doubt it but would see if others may chime in on this.
TIA.
Old 09-17-18, 10:27 PM
Noeh
Noeh's Avatar
TIA.
Lexus replaced mine under warranty. The new part has been revised and fits tightly.
Old 09-18-18, 04:24 AM
tofuprod
tofuprod's Avatar
Yeah, that's the issue, she's had this replaced before under warranty and it's happened yet again. I'll see if there is some sort of resolution to this.
Old 09-18-18, 08:43 AM
Renarello
Renarello's Avatar
Mine has ripped and continues to slide back and jam into the
sunroof frame keeping the sunroof from opening all the way.
Old 09-18-18, 09:24 AM
E46CT
E46CT's Avatar
Received 2,155 Likes on 1,619 Posts
Is this a part that breaks or just simply falls off and has to be reattached? knock on wood my MY16 hasn't done anything weird and i use my sunroof every day. often times in 100+ heat. (I live in socal too)
Old 09-18-18, 03:21 PM
tofuprod
tofuprod's Avatar
For ours it just keeps falling off.
The first time they attempted to reattach the original on.
The second time they ordered a whole new part and replaced it under warranty.
I have an appointment for next Wednesday to bring her car in (for a third time)and they will give me a loaner and hopefully will give it a more in-depth diagnosis and actual fix to this issue.
I will update upon pickup as well as within a few month's time after to give a status report.
Old 09-18-18, 03:38 PM
a1rh3adsz
a1rh3adsz's Avatar
The trim piece you guys are referring to is it the rubber round seal that is on top of the roof around the glass?
Quick Reply: Opened my sunroof and a trim piece fell off
