Nav Screen Scratches
Old 08-03-17, 12:27 PM
SikhSipahi
SikhSipahi's Avatar
Default Nav Screen Scratches
Is there even a way to clean the nav screen without scratching the anti glare coating?? I've had the Anti Glare coating replaced on my IS a while ago. Well I decided to clean it today, because one of my friends touched it the other day thinking it was a touch screen. I used a lens cleaning cloth and guess what!! It's scratched again!!! It's so annoying that this thing gets scratched even with so much care.
Old 08-03-17, 12:56 PM
kwb18
kwb18's Avatar
I just had mine replaced. I won't be putting any cleaner on it. I would suggest using a soft microfiber towel. Once again with no cleaner.
Old 08-03-17, 01:10 PM
SikhSipahi
SikhSipahi's Avatar
I didn't, it was just a damp cloth to remove the dirty finger print. I would suggest not using any cloth at all, just clean it with air pressure.
Old 08-03-17, 01:13 PM
kwb18
kwb18's Avatar
Good looking out. I noticed mine was dusty this morning and I was scared to even touch it with anything.
Old 08-04-17, 01:31 PM
Chedeng88
Chedeng88's Avatar
So the TSB replacement is still the same scratch prone screen?
Old 08-04-17, 01:51 PM
SikhSipahi
SikhSipahi's Avatar
It's the same thing. They don't replace the screen, they just wipe off the old coating and put a new one on. It will scratch no matter what type of cloth you use.
Old 08-04-17, 07:44 PM
specONE
specONE's Avatar
No that is not what they do. They replace it with a updated part number. . The entire front screen piece is replaced
I don't know if it's just a prone to scratch as the original is but I'm not gonna attempt to try my luck
Old 08-04-17, 08:12 PM
SikhSipahi
SikhSipahi's Avatar
Are you sure?? Because the issue was never the screen, it was the anti glare coating. It says "Dealers will replace the coating" on the TSB. How are you suppose to clean it, If someone touches it?
Old 08-04-17, 11:26 PM
specONE
specONE's Avatar
I'm pretty sure
https://drive.google.com/file/d/0B-a...w?usp=drivesdk
Old 08-05-17, 09:50 AM
premier3IS
premier3IS's Avatar
just use a damp microfiber and wipe it using a dry one after.
Old 08-05-17, 03:31 PM
greatone99
greatone99's Avatar
y not remove it ,i did ,it looks better without it ,glare never becomes a problem ,and it won't scratch just by cleaning it
Old 08-07-17, 08:52 AM
Chedeng88
Chedeng88's Avatar
What did you use to remove it?
Old 08-07-17, 02:32 PM
kwb18
kwb18's Avatar
I bought a duster so I'll just keep it clean that way and will kill anyone who tries to touch my screen. haha!
Old 08-07-17, 03:26 PM
greatone99
greatone99's Avatar
u wipe it with some invisible glass and a microfiber ,takes an hours but it will break down the coating
Old 08-08-17, 09:25 AM
otakusan
otakusan's Avatar
once you got it cleaned, order a clear screen protector (just like ones for your smart phone) oof of amazon or something. You will never have to worry about scratching it ever again.
Quick Reply: Nav Screen Scratches
