Have anyone broke their side mirrors changing the puddle lights?
I changed all my lights to LED except the puddle lamps. I watched the video. He makes it look so easy to pop open.
Is there a trick to it?
If the mirror or the plastic breaks, how much does it cost to replace? The mirror really cost $35 to replace?
I don't know on this one. I changed every bulb in my car except the puddle lights because of my experience changing the mirrors in my wife's car and breaking one of the little plastic clips that hold the mirror into the frame. Toyota and Honda love to use those little plastic clips and they break ALL THE TIME! just change everything else out and ignore the puddle lights...
GR3Y5H3ART (03-03-20)
I changed the puddle lights on my car. Honestly, the trick to popping it is just not being afraid. I kid you not, I spent 20-30 minutes attempting to pop it but couldn't because I was so scared of using too much force. I was holding back (and this actually hurt my fingers). Finally I just said f it and went for it. Just do it.
I really do want to do it since I bought the LED for the puddle lamp. What is the trick to pop it open? Is there a corner or side I should start with that makes it easier to pop out?
have to be careful, take off the back cover first (use plastic tool/credit card ect) and slowly go around the edges.
dont pull from the top, but on left and right sides to pull off when ready to.
The trick is to do it quick and not slowly pull. The tabs are designed to give a little and go back into shape just as long as you do it fast. Also do it on a warm/hot day. Don't do it in cold, plastic is more prone to crack as it is brittle when cold.
Do as you in video and do quick jerk pull motion and you'll be fine
lol sooo true. Plastic clips in general that hold so many things in our Cars for me is better to break off and replace than saying damaging an Interior Panel where fore mentioed Plastic Clip latches on to
what i found SUPER helpful is don't use 1x Flathead Screwdriver or even try using 2x Screwdrivers on either side...this again...rarely used tool works wonders:
![Have anyone broke their side mirrors changing the puddle lights?-as4kmuw.jpg](https://www.clublexus.com/forums/attachments/is-3rd-gen-2014-present/488233d1683151152t-have-anyone-broke-their-side-mirrors-changing-the-puddle-lights-as4kmuw.jpg)
I replaced all my interior, puddle lights and signal lights with LED.
1. Never use a metal tool to pry. Those plastic tool kit above serves as a complete tool kit for interior lighting.
2. Puddle lights - I would not recommend doing it when it's cold outside (plastic tend to get brittle when its cold). The only critical part is removing the mirror - this took me several tries before I finally yanked it out. Really feels like you are about to break the glass in half and eventually it will pop out. Several videos in youtube shows how to remove it.
Btw, the heated mirrors are more than $35 so be very careful.
$35 loooool
