What should my tire pressure be on my 2016 Lexus NX200t and how can I change it.
Old 08-27-17, 03:58 PM
prthompson
prthompson's Avatar
Default What should my tire pressure be on my 2016 Lexus NX200t and how can I change it.
What should my tire pressure be on my 2016 Lexus NX200t and how can I change it. The tire pressure warning light is on.
Old 08-27-17, 04:00 PM
premier3IS
premier3IS's Avatar
you're on the 3IS forum.... look up and see where you posted..
On a side note, search the forum next time.. you're not the first asking about this (I looked, plenty of threads on this topic there as well as what it should be at)
Old 08-27-17, 08:37 PM
Jay89
Jay89's Avatar
look on your door sticker. should tell you what the recommended pressures are. do not go with what the tire says. That is max pressure the tire is rated for, not what your tire pressures should be set at. Door sticker should be on the drivers side below the door latch anchor.
If you've ever filled up a bike tire, its the same. a foot pump probably wont be strong enough so go buy yourself either a portable pump or use one at your local gas station. a tire gauge is available at any parts store. I have a digital one i keep in the car at all times. I like being prepared so i keep a tire patch kit in the car as well at all times. I replace the kit once a year if i don't use it up, because the glue and rubber can dry out and may not work as well.
Old 08-28-17, 09:38 AM
arentz07
drives cars
arentz07's Avatar
Received 3,762 Likes on 1,908 Posts
Side note, I use a bike pump for my car's tires. It's rated for up to 40 PSI and is pretty easy to get the tires up to spec (typically about 3 pumps per PSI).
Old 08-28-17, 10:06 AM
E46CT
E46CT's Avatar
Received 2,158 Likes on 1,621 Posts
The MFR usually recommends something. but you can go from anywhere from 30 to 40 or even a bit higher.
personally i'd go 36-38 all the way around. Call it a day.
On my IS, I have 39-40 all the way around. Cold. I just did it for fuel economy. But i suppose it's a tad high.
Old 08-28-17, 06:12 PM
Jay89
Jay89's Avatar
nice, I really didn't think they'd be strong enough...or maybe that was me haha. I'm pretty small so a bike pump wouldn't work for me. For anyone on air, you can always use the tank to fill. It's what I did on my Subaru lol
hkbruin2
RX - 4th Gen (2016-2022)
01-10-16 04:51 AM
Rustito
11-01-14 08:53 AM
uae
03-10-08 09:16 AM
mjr24
Wheels, Tires & Brakes Forum
09-10-03 05:53 AM
kjbro
07-29-02 02:00 PM
Quick Reply: What should my tire pressure be on my 2016 Lexus NX200t and how can I change it.
