need help!!
need help!!
hi guys...i need help for my rims...i got STANCE SF01 19X8.5 + 33 and 19x9.5 +45 ...the rear tire keeps on rubbing..my tire size is 245/35 front 275/30 ...i wanna know if i can use any other tires size for this rim..my car is awd so i need tires that has the same rolling diameter...tnx!
275 is too wide 265 might work but 255 is probably better because of the offset. The tire will have a slight stretch. My first set of wheels were
front 19x8.5 offset 30. 235/35/19
rear 19x9.5 offset 40. 265/30/19
Received 1,738 Likes
Unfortunately you will have to replace all 4 tires.
235/35 and 265/30 are your best bet.
Next step down in size is 225/35 and 255/30...which will match closely with the stock F Sport diameter wheels.
^^+1...since you have 245/30 in front, you've committed the back to being 275/30, or something comparable in that diameter.
235/35 and 265/30 have the same rolling diameter for the purposes of the AWD.
The +45 will clear the fender for sure with the 265.
Although you never said where it was rubbing...
whew! thank you so much Sasnuke ...this answered my question...now im thinkin what brand of tire should i get..it seems like everybody got the hankook ventus tire..
Look at the Tread Width and try to select one that has the smallest Tread width.
Even though all 265/30/19's are supposed to be the same, there is a variance from manufacturer to manufacturer.
A tire that is less square (or more rounded, however you want to look at it), will have a smaller Tread Width.
This will give you a little more clearance and piece of mind.
Example below...ignore the actual number as that is a 20 inch rim...I had that pic saved for something else...can't remember what though.
hi again sasnuke..got a question bro...somebody wants to trade rims with me...he's rims is Vossen CVT's 19x8.5 +32 front 19x10 +42 rear with 235/40/19 front 275/35/19 rear ...u think the rear is gonna rub with this offsets ? and do they have the same rolling diameter?coz my car is awd
Doodlebug above has the same size/offset rim on the rear and he claims no rubbing with a 275/30/19 with RSR Half Downs...but also never has a full vehicle.
If he would let you test fit them, that would be the only way to tell. It's gonna be close.
They have the same rolling diameter. The only concern is with the 35 sidewall on the rear. It makes the tire taller than a 275/30/19.
If you do lower the car, you would have to be careful by how much.
And hopefully you never fill the back seat with adults...
renren7
SC- 1st Gen (1992-2000)
05-27-09 03:30 PM
