A tire question (flat tires aren't fun)
Hope you guys don't mind yet another tire thread but I've only had my '14 IS350 F-Sport for a about 6 weeks and could use some help.
Whoever had my car before put really cheap tires on her (Velozza ZXV4). I figured I'd go with them until they were worn out and upgrade. It's not going to work out that way, however, since something sliced one of my rear tires last night. I tried to plug it but it was a slice and not a puncture. So it looks like I'll be buying tires for my car, which is 100% stock, BTW.
With my S2000, I had staggered sizes and the rear tires wore out twice as fast as the fronts (could be my driving made this even worse). So when I replaced the tires I just did 2 at a time. The car came with Conti Extreme Contact DW tires and I just stuck with those (I only put 17k on the car in 5 years, it wasn't my daily driver, my Taco was). With my IS350 also having a staggered setup is it OK/normal to replace tires 2 at a time like I did with my S2000? Do the rears wear faster than the fronts? I'll likely keep the car stock for a while, so I'm assuming I should just stick with the stock size. Is that a good assumption.
And....yes, I'll take any recommendations on brands, etc. if you don't mind adding that information.
Thanks
p.s. - for anyone in or around Raleigh, my tire went flat when I was in the left turn lane trying to get into the WRAL soccer complex at 6pm...if you or your kids train/play there you can guess how much that sucked!
Thanks
Received 1,737 Likes
Thanks
Thanks
Quick answer to your questions...yes you can just replace the rear tires if that is all that is needed...stick with the stock size.
I would suggest to pick a brand that also makes the stock size for the front, so when you change them, you will have a matching set now. Many brands will carry both front and rear sizes, so should be fairly easy to pick one.
Michelin or Conti are both great choices for quality tires.
There is a thread somewhere on here with what folks use for tires, and I think Conti and Michelin are the vast majority.
Depending on alignment, tire pressure, and driving style, will really depend on what wears faster. For you, I'm going to guesstimate that you will be wearing out more rears than fronts...lol!!
elvis14 (09-01-17)
Hi Elvis...welcome!
You can do two at a time. Go with big factory corporate names and you'll do well!
elvis14 (09-01-17)
Ironically I was reading your $60 Brake Pad thread just now when you replied. Thanks for that too, it'll come in handy one day!
SC400_408
Wheels, Tires & Brakes Forum
04-05-07 10:47 PM
