Hey just wanted to upload some photos of the replacement of the OE Xenon lights my Glacier Frost 2007 Lexus IS250 with the VLAND's. After 13 years the headlights had yellowed from UV rays and even with using Chemical Guys technique to remove the surface layer they stayed "clearish" for only a few months. I tried a liquid seal but didn't help much. The most annoying part of the install was just putting the Bumper back together on the bottom with the retainer clips. Living in Canada you CANNOT turn off the DRL using Toyota techstream as other had mentioned in the States, no option for it, but VLAND must of updated the firmware because it's plug and play - the high beams do not act as the DRL as some users had noticed. Only the strip is illuminated which works out great since there is no flickering possibility because of voltage issues.
