Retro Fit 2017 F-Sport to 2014 F-Sport
No you wouldn’t need them. You can use the ones your 2017 already has. I believe only the ones with previous years need it.
If purely for performance, I would not swap to the triple beam LED. In terms of output, it's a downgrade with poor performance.
Low beams:
LED projector : 79/42m (right/left)
Triple Beam LED 66/33m
High beams:
LED projector: 155/154m
Triple Beam LED: 135/125m
Triple beam does look better appearance wise, but performs poorly.
The strongest car on the planet thus far is Prius V with its highly-regarded Koito Bi-LED unit. We can't get strong LED performance in our ISs because of its small form factor. You need (with current state of lighting tech) a large headlight like a Prius with room to disperse the heat LEDs generate. Can't do that in a performance sedan with sexy styling therefore smaller LED/heat management is used and therefore lower output.
I'm one of the strongest lighting "gurus" from over in the BMW world with tons of swaps/retros under my belt. This is my bread and butter.
Don't swap to triple LED if you want performance.
Low beams:
High beams:
Low beams:
High beams:
Low beams:
High beams:
Yeah it is mainly for looks I would say. Not need of much lightning here in California City area. If anything I will try and find a way to retrofit fog light like the GS-F style in the future for better lighting.
I tried puting my tail lights from my 2017 is350 f sport on a seibon trunk I ordered and they are not close to a direct fit. Housing is close but will need body work to fit flush. Just throwing it out that you may need the trunk for your conversion.
^not even sure what i'm looking at. the pictures are way too close. far shot for reference?
Your case may just be a poorly made mold of the trunk by seibon. bad current batch if others had good luck in past.
![](https://www.cstatic-images.com/stock/900x600/1376422496263.jpg)
![](https://lexusenthusiast.com/images/weblog/x16-09-12-lexus-is-standard-2017-rear.jpg.pagespeed.ic.x5mDAI-1hP.jpg)
I received my rear diffuser from seibon and after looking and trying to fit it, i turned me away from seibon forever. I ended up selling it off due to how poor it was made in my opinion. The whole time I thought i was doing something wrong but during the drying process they allowed some mounting points to dry in a totally different angle (45 degree) and was no way I was able to install it like OEM would've.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hi,
I have seen these square Triple Beam Headlights which would fit my 2017 IS300. Can anyone please help me out on where I can find them, also the contact information of a dealer that has them. I asked one other fellow, but all he said was Japan. Talk about being vague here. I asked him where in Japan. No answer.
They're about $1500-2000 a side from Japan eBay
https://www.ebay.com/itm/NEW-LEXUS-I...xaTkxA&vxp=mtr
Hi,
http://ebay.to/2DiNLqb
