How can I reset tire pressure warning light on 2017 IS200t?
I just bought a IS200t, but few days later, the tire pressure warning light continuously stays "ON". I checked all tires pressure are normal.
Begood9394 (11-01-17)
I read few articles with regarding tire pressure reset button, but I cou
ldn't find it @_@, I have also checked the user manual, it is NOT clear. refer to the attachment...
Just check the sticker on the driver's door jamb and inflate all the tires to the said pressure.
Then ignition on (do not start the car) and hold the "SET" button under the steering wheel until the TPMS light on the dash blinks. Then sit in the car for a few minutes for the system to calibrate and you're good to go.
Thanks for all help's information, but..I follow all instruction, but still not reset
I check all tire pressure is approx 280kPa, but the warning light still ON. I have found the Reset Button, and I place and hold on the button for a while, it didn't blink? Have I done something wrong?
I have contacted Lexus Service center, they said they have changed 2 tires for me before I pick up the car. They think maybe they have forgot to register ID code for those 2 tires. @_@
If they didn't register ID code, the reset button won't work. @#$%^&* Therefore, I need to drive the car, what a inconvenience.....
