is 300 rims (215 45 17) will it fit a IS 350 Fsport
Hi
Does anyone know if the rims of an old 2002 IS 300 (215 45 17) fits the IS 350 Fsport as I have a set and would like toi use it for my winter tire package
Thankls
Thankls
The rims should fit. The bolt pattern is 5x114.3 and center bore 60.1mm is the same. Check if offset (ET) is enough to clear the front brakes. If you have the wheels, mount them on the car and see. I believe (215 45 17) is slightly smaller than required (225 45 17), your speedometer might be off just a bit.
https://www.wheel-size.com/size/lexus/is/
evident
04-14-15 08:42 PM
shui3000
09-29-11 03:46 PM
