Will 19x9.5 +35 and 19x10.5 +45 fit an IS250 awd?
Hello all,
Quick Q: I have an ISF but I have a local guy interested in my Weds Sports SA15R. He drives a 15 IS250 AWD.
1. Will 19x9.5 +35 and 19x10.5 +45 fit without fender mods? Tires are 245/35 275/30, but nearing end of life so he may change/stretch. He said he will not go lower than mild springs.
2. Is staggered wheel/tire setup allowed on AWD 3IS without issues?
Thanks in advance!
Thanks in advance!
Hello all,
Thanks in advance!
Thanks in advance!
Yes they will fit , he might need to go with a 265 tire in the back though. I had almost the same set up , i had 19x9.5 +35 and 19x10.5+40 in the rear with a pretty significant drop on coil overs all round. he will not need to mod fenders unless he wants to go really low other that that hes good! im AWD as well and no it is not bad to go staggered because the stock set up is already staggered , as long as the difference isnt too big and you try to keep the same staggered ratio. 265/30 would be a perfect set up but 275 shouldn't be too different
netsrac
06-16-24 09:15 AM
gcomme2
11-15-15 06:02 AM
