I like how quite the stock exhaust is but I want to have the quad look. So I am going to cut the exhaust tips and weld the quad exhaust tips (dual on each side) to the stock mufflers. Do you know what size is the stock exhaust inlet? Is it 2.5" or 3"?
Also what is the good size for the quad tips? I like the look of this set up, but not sure what is his exhaust tips size.
Those are 3.5 I believe. I have the same set up. But they won't fit on the stock diffuser obviously.
I just bought this diffuser. Fitment is very bad. Did you have to do a lot of dremel or sanding to make it fit? Carbon fiber is strong as hell so you can't bend it obviously.
3.5 in is perfect , I have it on my stock 17 diffuser, I know a lot of guys run 3.5 or even 4 inches on that diffuser, personally I’d go 3.5. the inlet size is 2.25 !
