Lexus OEM RCF Auto Dimming rear view mirror DIY
#46
#47
drives cars
I actually don't like the RC clock surround at all. The grained plastic looks cheaper than the metallic-painted plastic in the IS. I wish they hadn't updated it for '17. Just my opinion of course.
#48
wow i like that rc clock. looks like it should fit?
anyway seems like the IS facelift uses the RC mirror now. cool
#51
cool mod!
personally i can never use whatever cool features newer model mirrors have because i always slap on a Broadway Wide View Mirror:
![Lexus OEM RCF Auto Dimming rear view mirror DIY-okjys3b.jpg](https://www.clublexus.com/forums/attachments/is-3rd-gen-2014-present/488450d1683151296t-lexus-oem-rcf-auto-dimming-rear-view-mirror-diy-okjys3b.jpg)
in the IS350, i still have to turn my head sometimes but it has come in handy in other cars
if you really hate ever turning your head, you can always up for the extreme version![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Lexus OEM RCF Auto Dimming rear view mirror DIY-v7k4xyg.jpg](https://www.clublexus.com/forums/attachments/is-3rd-gen-2014-present/488451d1683151296t-lexus-oem-rcf-auto-dimming-rear-view-mirror-diy-v7k4xyg.jpg)
#52
#54
#55
#56
drives cars
I'm really curious now about this. I may have to try shutting the car off with the driver's window open and see if I can reach in and press the button. But if you can open the doors it is sort of a moot point.
I believe you can set the car to automatically lock, but I don't recall how.
#57
Never even thought of this, but doesn't the car lock on it's own after a few minutes? I think after I got my COMPUSTAR remote start, the car locks on it's own. I remember there were times I forgot to lock the car and it would stay open all night. I've let the car sit a few minutes and I hear it lock on it's own, not sure though.
#58
Pin 1 (Blue): Ignition Power
Pin 2 (Puple): Ground
Pin 3 (not on ewd?)
Pin 4 (Green): Signal for light control
Pin 5 (White): Signal for light control (both are MPX)
Pin 6 (Pink): Power
Pin 1 is fused with the 10A IG1 NO.3 fuse
Pin 6 is fused with the 10A MPX-B NO.1 fuse
#59
drives cars
im thinking about at getting a 3IS and have the same concerns. A quick solution would be to remove the fuse tied to pin 6. But this may make the homelink useless among other items. Another option would be to cut the pin 6 wire and tap it into the pin 1 wire.
Pin 3 (not on ewd?)
Pin 6 (Pink): Power
Pin 3 (not on ewd?)
Pin 6 (Pink): Power
But even if you have one of those remotes for opening the garage door, it would have the same problem. Those are battery-powered and work no matter what. You'd have to remember to remove it from the car.
#60
(Neighbor’s event was not a HomeLink case, but rather his wife left her car unlocked and had a physical remote for the opener in the car.)
