IS350 Speaker Sizes
Old 12-21-17, 01:00 PM
GibbsLexus
GibbsLexus's Avatar
Default IS350 Speaker Sizes
What are the sizes of our speakers? I am considering going aftermarket for door speakers and maybe the sub.
Old 12-21-17, 01:56 PM
specONE
specONE's Avatar
Standard,
Mark Levinson
The following 8 users liked this post by specONE:
AtomicAWD (12-23-18), Flashkid (02-21-18), Gladius (01-14-20), imyang (11-25-20), ken97 (07-19-20), mcomer (02-19-18), Noeh (11-28-20), zhieson (01-17-19) and 3 others liked this post. (Show less...)
Old 12-21-17, 07:17 PM
GibbsLexus
GibbsLexus's Avatar
thx SpecOne
Old 02-19-18, 12:07 AM
TxPride
TxPride's Avatar
Haven't been on for a bit and tried a half *** joke..
thanks for the great diagrams
Old 12-23-18, 10:01 AM
lychee416
lychee416's Avatar
Originally Posted by specONE
Standard,
Mark Levinson
Thanks spec, is the location 1 speaker really a speaker or a mic for bluetooth?
Cervantez (10-31-21)
Old 12-23-18, 01:03 PM
specONE
specONE's Avatar
it really is a speaker located there.
The microphone is located overhead in the maplight console.
Old 12-23-18, 02:08 PM
lychee416
lychee416's Avatar
Any place I can put tweeters? Should I remove a couple of speakers and put tweeters instead? I was thinking of buying 2 pair of focal speakers and one sub with amp in trunk.
Old 12-24-18, 12:02 AM
AtomicAWD
AtomicAWD's Avatar
That's your center channel! You could put tweets in location 2 but your only other fronts (if non-ML) are 7" so not a good match. Better to put in coaxials, 4" (if they'll fit) with a nice soft-dome tweeter.
Old 02-27-19, 09:54 PM
AtomicAWD
AtomicAWD's Avatar
Something's odd about those speaker specs. The "rated input power" is far less on the MLs, even ridiculously low. An 8" woofer that only handles 8.5 watts?
The non-ML 8" is 2.5ohm whereas the ML is 6ohm, so evidently they are different. Does anyone know the diameter of the hole for it in the rear shelf, and also if the amp back there is full range or pre-amp crossed over, or the speaker passively?
Old 03-02-19, 08:35 AM
nquinn
nquinn's Avatar
Anyone know what kind of amplification these systems use?
I'll say having 6.5-7" speakers all around is a pretty great start compared to some cars. Is the single rear 8" speaker in the back low pass filtered to act as a subwoofer of some sorts? Seems odd to have only one.
Old 07-09-19, 09:14 AM
zhifan1
zhifan1's Avatar
Looking to buy a pair of speakers for the rear passengers', can i safely say that it is a pair of coaxial speakers? Any recommended ones? I just upgraded the fronts and also added a processor and changed the woofer. Now looking to upgrade the rear for a "complete" feel. Any brackets and adapters i should get as well?
Old 07-09-19, 09:33 AM
AtomicAWD
AtomicAWD's Avatar
I would assume the sub is low-passed as the drivers in the front doors certainly are.
Old 10-21-19, 08:10 PM
Saf1993
Saf1993's Avatar
I have a ML system, and the sub rattles,
What's the best option to replace the sub?
Old 10-22-19, 04:53 AM
robawrench
robawrench's Avatar
For sub replacement on the non-ML, I read on another post that a dual voice coil 8" sub is a great replacement for the rear center sub. If get a 4 ohm speaker and you wire the two voice coils in parallel, you'll get a lower impedance that will get close to the factory 2.5 ohm speaker.
Has anyone used an MB-Quart DS-1 204? for the rear sub? This is a shallow mount. I'd like to use it without adding an amp. I know adding an amp would be better, but working in steps.
Old 12-26-19, 05:02 PM
enkrypt3d
enkrypt3d's Avatar
What sized speakers did u get for the front? And did you use a bracket? The OEM size is 7" so it's not the same as a 6.5" aftermarket......
https://www.crutchfield.com/p_091PC1...l-PC-165F.html
I was going to get 4 of these for the doors.
Gladius (01-14-20)
Quick Reply: IS350 Speaker Sizes
