Gauge cluster swap
My IS has factory navigation and the cluster I bought came from a vehicle with factory navigation. There is a blue connector on the back of the cluster that is used for navigation information. I’m sure the cluster would operate, but you may have an error message and/or an unusable navigation menu.
In BMW world the vin# in the cluster EEPROM has to match the vin# in the DME (ECU) or a tamper dot (code) will appear and it'll show the cluster is tampered with. and that's on a 15 year old car. i'm sure lexus has something more sophisticated nowadays??
So I did swap a base is250 with a 350 fsport instrument cluster. Everything works, but I get the warning lights turn on every time. Check for vgrs and pcs. I don't know how to remove these error as my car doesn't come with those system.
Received 1,736 Likes
Did you get a 350 cluster from the same year as your 250? Do you know the part numbers of each cluster? Do you have a Techstream to check the codes?
I agree with you. As far as comments about it being prone to failure, I thought that might be the case, but I use the sliding function so rarely that I'm not really all that concerned about it.
If you can find out what the code is, it might give you an idea of what needs to be done to clear the light...or at least trick it into clearing.
Honestly if you had gotten the 250 F Sport cluster from a vehicle the same year as yours, then everything would have been fine...no lights.
Frankly, I'd probably rather have the traditional cluster. Have always had the dual gauges in all my cars... maybe just tradition, but it looks far more sporty instead of techno, imo.
F Sport cluster is definitely way cooler and sporty IMO. I haven’t met anyone who has said the IS dash would look better with the traditional tachs.
That being said, I haven't driven with it at all, but it looks like you get things like the mini-map without having to slide the main gauge, and a lot of the other info given isn't all that necessary or important. Then again, maybe I'm just ooooold and stodgy...
Your wait it over! ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Interestingly, it was maybe the one downside of F-Sport for me. The outside looks, seats, etc. are all better than base, although apparently things like rain-sensing wipers were only available on the base in 2014. That's also a thing to ponder -- while we obviously want a car pleasing to look at, in fact we spend a whole lot more time inside it than we do looking at it from the outside. But even if it had a "perfect" interior, the lesser looks would still bug me to no end.
drives cars
But even in daily use, I like it. Very easy to read and bright. And I like being able to use it for a slightly clearer view of turn-by-turn nav whilst controlling music on the other screen... things like that.
It's a nice party trick for sure. Especially the moving ring. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
