Still can't get used to turn signals
Old 01-24-18, 09:55 AM
RKSTRAT
RKSTRAT's Avatar
Default Still can't get used to turn signals
When I want to tap to pass, I hit it too hard.
When I try to stop it, I hit it too hard the other way!
Old 01-24-18, 10:52 AM
CLUM
CLUM's Avatar
i hate them. If it ain't broke, don't fix it Lexus! lol i miss being able to quickly turn them on or off.
davyjordi
davyjordi's Avatar
first world problems.
Old 01-24-18, 10:54 AM
doodlebug
doodlebug's Avatar
It didn't take me long to get used to them. I love them. Especially since I changed the 3 blinks to 5 blinks.
Old 01-24-18, 12:50 PM
tabjohitol
tabjohitol's Avatar
I've had the car for 3 months and still can't get used to it either. My turn signals are all over the place when changing lanes.
Old 01-24-18, 12:55 PM
arentz07
drives cars
arentz07's Avatar
Received 3,798 Likes on 1,927 Posts
Just be gentle with them. Took me about two days to adjust, and I had never had a car with turn signals like them before. If you go easy on them, you can feel them click into place when they go all the way over, and there's a tiny bit of resistance before you go that far that you can use to stop. TBH, I've never thought they were hard to use, and certainly easier than BMW's implementation.
Old 01-24-18, 03:26 PM
CarlitoIS
CarlitoIS's Avatar
How did you change it from 3 to 5? You mean when you slightly tap it?
Old 01-24-18, 03:33 PM
doodlebug
doodlebug's Avatar
Yes - the process can be frustrating, it took me a couple of tries.
​​​​​​https://www.clublexus.com/forums/is-...s-to-more.html
Old 01-24-18, 04:13 PM
skiracer
skiracer's Avatar
Same problem here
Old 01-24-18, 04:23 PM
premier3IS
premier3IS's Avatar
dealership programmable option. changes the blinker to go from 3 to 5.
Ohtexan (09-02-21)
Old 01-24-18, 04:28 PM
mjeds
mjeds's Avatar
option is 3, 5 or 7 a Carista can do it as well
Old 01-24-18, 04:31 PM
premier3IS
premier3IS's Avatar
I was going to mention 3,5 or 7 but I forgot if it was 7 or 8 lol.
I have mines set on 7 as well.
by the way, parked next to an RC-F the other day.. had to double check the license plate frame to see if you were in town lol
Ohtexan (09-02-21)
Old 01-24-18, 04:41 PM
mjeds
mjeds's Avatar
by the way, parked next to an RC-F the other day.. had to double check the license frame plate holder to see if you were in town lol
Ha.. I passed through about a month ago and was in Campo for a few days visiting family.
Old 01-24-18, 06:29 PM
EXE46
EXE46's Avatar
I'm the opposite of you, loved the BMW's hate this one.
Old 01-24-18, 08:57 PM
specONE
specONE's Avatar
Can do change the blinks to 3 or 5 or 7 manually too by doing a Dance in the car.
Follow this procedure. It may take a couple of times to get it right, but it works.
1.) Ignition off, doors closed
2.) Hold the wiper switch in the full up position. (this is the wiper off position)
3.) While holding the wiper switch in the full up position, turn the IG on. (two presses of the start/stop switch)
4.) Hold wiper switch in the full up position for 5 seconds
5.) Move the wiper switch down one "click" or "notch", hold for 5 seconds
6.) Move the wiper switch back to the full up position, hold for 5 seconds
7.) Move the wiper switch down one "click" or "notch". hold for 5 seconds (same position as step 5)
8.) Move the wiper switch back to the rest position (neutral)
If this was done correctly, the right turn signal will flash once.
To adjust how many flashes you want, you change the intermittent wiper speed switch. P1 starts with the speed switch all the way at the bottom, P4 will be the top speed. This is found on the wiper stalk.
P1: 3 blinks
P2: 5 blinks
P3: 7 blinks
P4: Function turned off
Set the intermittent wiper speed to the desired setting.
Use the Turn Signal stalk and push down like you want to activate the left turn signal, the flashers should activate
If the turn signal blinks once, you change it to the "3 flashes" setting
If the turn signal blinks twice, you changed it to the "5 flashes" setting
If the turn signal blinks three times, you changed it to the "7 flashes" setting
If the turn signal blinks four times, you turned the function off.
Once this is done, cycle the ignition switch off, and back on, and it should be changed.
The following 5 users liked this post by specONE:
CriMe (01-24-18), landonm86 (09-06-21), Matroushi (01-25-18), RKSTRAT (01-25-18), zhifan1 (01-25-18)
Quick Reply: Still can't get used to turn signals
