Headlights and LED swish lights wont turn on at the same time
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have a Lexus IS250 F sport and was having trouble with my head lights and DRL lights not working. I took it into the dealership and they found that there was some corrosion on one of the clips which they replaced for me and now I can’t keep seem to get the headlight and the LED DRL lights below to turn on at the same time or when the car lights are set on auto. When in auto the headlights are on and the LED DRL lights are off. When it’s on low beam, the LED DRL light below the headlights are on but the headlights are off. How do I get them to both turn on at the same time? I basically need to look like this https://www.clublexus.com/forums/is-...time-pics.html
go into your car nav setting and see if you have the DRL off. If they are off, set them back to on and you should be good. If its still a no go, bring it back to the dealer and have them look at it
Thank you for the suggestion but that didn’t work. I’m in Canada so we don’t have the DRL setting option as they automatically have to be on. Also, I currently have the sensitivity on the highest.
worldcat
NX - 1st Gen (2015-2021)
14
10-22-18 08:05 AM
09starfire
07-27-16 10:25 AM
jeeper2269
10-22-14 03:15 AM
