RC remote touchpad in a 3IS?
Old 02-01-18 | 10:56 PM
specONE's Avatar
specONE
Default RC remote touchpad working in a 3IS
How many of you ever thought of installing the RC350 navigation remote touchpad armrest console in our IS?
I have, ever since the car was released in 2015, I wanted to take one apart and see if i could swap the two.
You can, Sorta......
Well I have finally figured out that the connections are actually different when comparing the Remote Touchpad vs the Remote Joystick.
The RC Remote Touchpad is a 10-pin plug while the IS Remote Joystick is a 16-pin plug
But it still can't be so different that the two couldn't interchange though right? So i studied the wire schematics between the two and found out they have the same amount of wires and i just needed to make a wire harness adapter to be able to plug in the Touchpad to give it a try.
I made a make shift Frankenstein Harness adapter out of scrap connectors and wires terminals I had laying around following the both wiring schematics so that way I do not chop up the cars wiring.
I had it all wired up and gave it a shot, knowing well that there is chance i could do some damage to my stereo (out of warranty now) or the touchpad. Gave it a go and what do you know, it worked!
Thought I'd shared the discovery with the community.
Touchpad work with vibrating hapi-tap feedback as well,
"Menu" and "Home" button works.
Unfortunately the Back button did not work.
Knowing this now, a harness can be made and I think the full center console Armrest can be swapped from a RC to a IS no problem.
The last switch is the ECO/Normal/Sport switch to see if the connection is the same there or not. If it is not a wiring harness can be made for that also probably.
So now you know if you ever thought of retrofitting the RC center console in a IS you know its possible electronics wise.
Who's ready to attempt the full retrofit swap?
The following 6 users liked this post by specONE:
anthonys2r (02-02-18), FamousBran (04-14-21), LexSense (02-02-18), mcomer (02-05-18), minhael (02-02-18), shirosan (09-28-18) and 1 others liked this post. (Show less...)
Old 02-01-18 | 11:26 PM
2jzdc's Avatar
2jzdc
That's pretty cool!
Old 02-05-18 | 10:37 AM
specONE's Avatar
specONE
guess this isn't that interesting to anybody really?
Old 02-05-18 | 11:11 AM
mcomer's Avatar
mcomer
If the "experts" at Consumer Reports have it right the joystick style remote controller
is less bad than the flat phone face style touch pad... Thanks to your pioneering efforts
it might be conceivable to retrofit the physical mouse to the pad equipped cars...
Old 02-05-18 | 11:58 AM
EZZ's Avatar
EZZ
I would rather have the mouse. I tried the crazy pad on a loaner and was not a fan.
Old 02-06-18 | 09:09 AM
Edwin8484's Avatar
Edwin8484
Maybe this could fix the problem you’re having with the android unit moving the joystick to one corner. Maybe?
Old 02-06-18 | 09:19 AM
mjeds's Avatar
mjeds
I've used both and Prefer the touch pad, anyone that spends a great deal of time using one on a laptop probably feels the same.
Old 02-06-18 | 01:53 PM
arentz07's Avatar
arentz07
I use a trackpad with my Macbook Pro for work all the time, but I despise the Lexus touchpad.
Old 09-22-18 | 08:25 PM
eddie420's Avatar
eddie420
So, I am wondering if this work with the 4GS... I want to try lol.
Old 09-22-18 | 09:13 PM
zhifan1's Avatar
zhifan1
Your DIY is on a whole other level... kudos for even trying! Now, as an aside, can you make the driver's side mirror dip when reversing?
Old 09-24-18 | 10:55 AM
Pittsy's Avatar
Pittsy
Can we swap the touchpad for the ****? I know you did the joystick but maybe the **** would work too?
Old 09-24-18 | 10:59 AM
E46CT's Avatar
E46CT
Cool but I'd rather see something like RC-F rear control arms on our cars. All the diagrams and photos i analyzed, it should be a direct plug and play swap =) lighter and solid balljoints rather than bushings.
but I can't justify trying it cause i won't be keeping the car.
Old 09-27-18 | 07:47 AM
Pittsy's Avatar
Pittsy
Bump. I really want to find out if this would work on a non-navi 3is?
Old 09-28-18 | 08:38 AM
specONE's Avatar
specONE
No it will not work on non-Navi **** control 3IS
Old 09-28-18 | 09:50 AM
Pittsy's Avatar
Pittsy
Dang. Wouldve been my next upgrade.
Quick Reply: RC remote touchpad in a 3IS?
