Help: I need help with tire sizing
I have an AWD with OEM 18' wheels & tires right now.
Specs for OEM 18' wheels & tires
18x 8 225/40 front
18 x8.5 255/35 rear
I'm looking into buying some wheels with the specs
18x8 +40 front
18x9 +45 rear
What tire specs would go best with these?
Thank you!
18x 8 225/40 front
18 x8.5 255/35 rear
18x8 +40 front
18x9 +45 rear
Thank you!
Received 1,736 Likes
If that is the case, then you can use the same size tires that are currently on the car.
Melomelo (02-20-18)
Melomelo (02-20-18)
ya, the difference in wheels specs are so small, you can reuse stock tires, or use same size tires if you plan on buying other tires.
Melomelo (02-20-18)
dnhemm
03-18-11 02:36 PM
