Power Rear Sunshade Retrofit
Hello all,
I have been looking through the forums in regards to retrofitting the power rear sunshade on our cars, however, I can't find a straight forward answer whether or not it is in the realm of possibility (i.e. not having to take half the car apart and running wiring).
Through my research, I've noted the harness for the sunshade should already be there, the only things that are needed are the sunshade itself, the button that goes in the dash, and the new plastic piece thats under the rear glass (the shelf from what I've seen people call it).
Can anyone provide some insight into this?
I had some press on shades on a prior BMW from a british company. I checked their website and don't see any Lexus available, but maybe you can hunt around to see if another company does it for Lexus
https://www.carshades.co.uk/
kj07xk (08-12-22)
Didn't take a pic sorry, but if you look behind switch panel (the one with parking sensor switch etc) there should be a spare blue connector to plug into sunshade switch. Much easier to check that than pull rear deck apart
CloudN32 (08-12-22)
Does your sun shade rear deck consist of two pieces or one pieces? I'm trying to source all the part that need to retrofit the shade assembly.
