Wheel Question
Hello,
I have a 350 AWD F-Sport running the stock setup, 225/40R/18 in the front, and 255/35R/18 in the back.
I want to pick up a set of Niche Forms that are 245/40R/19. Does anyone know if there will be issues with the AWD system as well as fitment?
Received 1,736 Likes
What are the rim specs that you will be putting the 245/40/19 on?
Assuming you meant +35, then likely the rim will fit just fine.
As for the tire size, the speedo would be off a noticeable amount.
Depending on what your ride quality needs are, I would suggest a 255/30/19 or a 245/35/19.
yungicon (03-09-18)
