AWD F-Sport and front tire wear
i was told i need to be keeping my tire pressure over 40psi and its been good ever since! Also @RRracing does have a fix for this a well!
http://www.rr-racing.com/Lexus-Lower...isfxlca001.htm
A lot of it is driving style. The F-Sport and base model share the same soft LCA bushings. I will venture and say the F-Sport drivers have a more "spirited" driving style.
This said driving style puts more torque on the soft durometer rubber bushings which leads to pre-mature inner tire wear. There's way too much evidence to pacify this conversation. Lexus has a problem with the bushings that need to be addressed...PERIOD!
With the higher durometer bushings comes a harsher ride. I believe Lexus hasn't changed them due to this issue. Ride quality is important for a luxury automobile!
Maybe Lexus should upgrade the F-sport models only.
BMW and Mercedes had this issue ever since bro along with Carbon buildup, LCA bushing isn't the only bushing on the car, many factor that causes inner/outer tire wear, i'm not saying LCA bushing won't cause tires worn out like this, if they are damaged yes they will, my question is, if Lexus LCA bushing is ...let say "defect" then everyone should have this problem right ? i'm sure they will have a recall, it is a safety issue. don't misunderstand its not because i don't believe you but anyone has this problem please write to Lexus Canada/America and let them know, when they have enough complaints they will recall .
I think there's plenty of evidence to support the LCA bushing upgrade as a solution to this problem for those who have it. However, at 17k miles, I have no evidence of inner tire wear on my IS 300 AWD F Sport (completely stock, btw). I drive somewhat aggressively - never at 10/10ths really, and some days I am pretty chill, but then again I do like to have fun sometimes. I have been checking for signs of this issue for a few months and not seen anything. So, you bring up a good point that not everyone has it, but there are so many factors coming into play that it can be hard to say. Obviously it's not well-engineered if it is as widespread as it would seem, whether everyone has it or not.
Secondly, Gen3 Lexus IS 350 AWD Fsport HANDLES SNOW STORM in TORONTO CANADA really DAMN WELL, i'm a guy that NEVER had SNOW TIRES on any of my car for 20 years, last year bought brand new set of snow tires and tested, i was impressed with Lexus IS, THIS YEAR, i bought a BRAND NEW YOkomaha All-Season tires and drove in this SNOW STORM , still have them on my car, i was like Damn you girl, i think i don't need Snow tires for my this gen3 IS , the relaxation feeling to drive in Snow STorm i ever experienced in any car. "bro i drove with this Yokomaha set all year around, no premature wears or inner wears, i put a set of snow tires on my Toyota Solara. My Solara is a LOWERED Car with TRD SPECS and CAMBER KITS installed, 15 years+ no premature tire wears, they wear normally like regular suspension. because i had Camber kits ! Alignment done every 2 years. TRD lowered 1.2 inch , i took it off lowered it 2 inches with AG Lowering spring. Made in Argentina .
Working as a Lexus Service Advisor I can safely say that there IS a problem with the LCA bushings.
My IS customers only get 20K out of their tires and its rather painful to have the alignment conversation with them once a year. There IS an issue and the FIGS / RR Racing bushings easily correct the issue.
I'm having the same issue except the tires are cupping with noticeable noise with less than 10k miles on Pilot Sport A/S 3+. This is my second set of them with my first set only lasting around 15k miles before I had to replace.
I know the bushing has been mentioned but can somebody check my previous alignment to see if anything could've been tweaked?
As far as the cupping goes, it is usually due to blown shocks or tire pressure. Again not much can do about it with the alignment.
Your IS having this Inner tire issue bro ? and Lexus ain't do anything about this !
Continental or Yokohama , i'm with Yokohama at 28k km tires looks new ! i had Michellin on my Solara, i get tire spins or understeer most of the time. old school Mechellin wears slower than others but the tires get harden and bad traction.
