F Sport Intake on a 2014?
Anyone know if the F Sport Performance Air Intake System, Lexus Part no. PTR03-53100 will fit a 2014 IS350? I believe they are made for 06-13 but they look identical to me.
for Non-Fsport Air Filter ! before i traded in my 2011 IS350 for 3rd Gen IS350 , i kept the brand new OEM air filter from 2011, brought the car home, tried to put on the 3rd Gen IS , DID NOT FIT, brought to the shop mechanic said, won't fit, it slightly different, not sure about Fsport one.
Really, I am just curious if the pipe will fit. I found a great deal locally, for an F sport intake. Part #: PTR03-53100. I believe the only difference is the lower intake box (which I will either cut or buy the f sport lower separately) Thanks!
I bought an HPS intake pipe, the FSport filter, and cut out a hole in the lower portion of the stock airbox behind the headlights. Saved money instead of buying the FSport intake system.
That's actually the other option I had. Exact same setup, including the hole cut in the lower box. How do you like it? Decent sound? Any issues?
The only differences between 2nd and 3rd f sport intake is the lower intake box and the tub cuppings. I did a mixed and match on my f sport intake before by using the 2nd gen tube because it had a f sport engrave on it and brought separate 3rd gen tub cuppings for it and kept my 3rd gen intake box with no issues. SpecOne had that idea and i just did the same thing.
