Parking Brake Pedal Cover
I have seen some people have the parking brake pedal that matches the other two and the foot rest cover, I am wondering if anyone has links to these two. I cant seem to find them.
Thanks!
Thanks!
I bought this from ebay to use for the parking brake pedal. Still haven't installed it yet though.
https://www.ebay.com/itm/Genuine-Toy....c100148.m2813
Still looking for the dead pedal.
There was another member that posted a "How-to" on switching up the parking brake pedal, I just can't remember who it was. I'm sure someone else will know who I'm talking about.
https://www.ebay.com/itm/Genuine-Toyota-Lexus-Manual-Trans-Aluminum-Clutch-Brake-Pedal-OEM-31321-53010/222590393502?_trkparms=ao%3D1%26asc%3D20140127102845%26meid%3D4d92e426bee242b6aa0b4cd758ccb5a7%26pid%3D100148%26%26itm%3D222590393502&_trksid=p2059210.c100148.m2813
https://www.aliexpress.com/item/Car-Accessories-For-LEXUS-RX200t-450h-IS250-RC-GS-330-350-IS250-AT-Accelerator-Brake-Footrest/32834756093.html?spm=2114.search0104.3.75.72476815DSTvWa&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10139_10307_5711215_10313_10059_10534_100031_10103_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=bbd557c0-4b6a-4935-8c2a-ac5db435aef7-11&algo_pvid=bbd557c0-4b6a-4935-8c2a-ac5db435aef7&priceBeautifyAB=0
No Drill
https://www.aliexpress.com/item/tomm...ceBeautifyAB=0
Using Toyota part number 31321-53010, which isn't a direct fit. I fabricated the foot pedal rest out of 12 gauge stainless steel (see attached .pdf) and fastened using an 8/32 locking nut and screw. Where the plate bends down the side of the e-brake arm, I placed another 8/32 nut with washers to pick up the edge of the tab bend down on the fabricated part. There's already a hole right in the center of the E-Brake arm and a slot on the side. So NO MODIFICATION to the car was necessary. It's extremely solid with no movement at all. If you need a .pdf version, please feel free to PM me.
I couldn't find a good replacement option, so I made my own!
Stainless Plate
Stainless Plate
Ok, so I found the thread I was talking about in my earlier post, with the "how-to" on mounting the pedal cover on the parking brake. Here's the thread. Scroll down the post #29, that's where you'll find his how-to.
https://www.clublexus.com/forums/bui...o-build-2.html
I also found the a dead pedal part number for a 2015 RC350 that should work for our IS. Here's the thread with the part number in post #11.
https://www.clublexus.com/forums/is-...ead-pedal.html
Hope this helps. I'm going to be ordering the RC350 dead pedal myself.
EDIT: I didn't read the full thread. It has already been mentioned. My mistake.
Here you go! https://www.clublexus.com/forums/bui...ml#post9573574
studio54
RX - 1st Gen (1999-2003)
06-01-15 05:35 AM
Lboogie300
05-23-06 06:32 AM
