Service at 41K miles?
My 3IS 250 just hits 41,000 miles. The service light on said "Schedule Maintenance is required". The dealership said it cost $329.99 for the service at 41K miles, or I could just do the synthetic oil change for $99.
Is it important that we have to the 41000 service cost $329.99 as they say? What services included in the 41K? What did you guys do at 41K? Just oil change or full service? Pls give me your advice.
Thanks
Thanks
Take a look at your owner's manual. It has a list of all the services that should be done at each given interval.
drives cars
So basically oil every 10k and replace brake fluid every 30k. (according to lexus)
all the other stuff is basically something a child can do. use eyeballs to look at brakes. use eyeballs to look at wiper fluid. check floormats. yawn.
personally i'd also add replace transmission and diff fluids/filters at around 36-40k.
i'd also add drain and recharge a/c system every 3 years (if you are keeping your car long term)
i'd drain and refill coolant at regular intervals too. maybe every 36k/3 years.
replace belts drive/ac belts every 36k (inspect and replace earlier if necessary though)
Lexus wants to give the perception of low maintenance so naturally they'll skip some key maintenance items. BMW does this too. "lifetime fluids." BS.
Or visit http://www.lexus.com/maintenance and follow the "Maintenance Schedule" link.
- Check Installation Of Driver's Floor Mat (I can do by myself)
- Reset Oil Maintenance Reminder, if Oil was Changed
- Perform Road-Test on Vehicle
- Rotate Tires (I can do by myself)
- Inspect Wiper Blades (I can do by myself)
- Inspect /Adjust All Fluid Levels (I can do by myself)
- Replace Engine Oil With 0W-20 Oil, And Oil Filter
- Replace Cabin Air Filter (If Equipped) (I can do by myself)
- Visually Inspect Brake Pads, Calipers and Rotors (I can do by myself)
@babiiryan Double check if you actually need to do a tire rotation. If your wheels are staggered, you wont necessarily need to.
my pads were replaced at 11k =)
Best to remove the wheel and peer into the brake window (if you have the big F sport brakes) but you can also get in there with a flashlight w/ the wheel on and kind of see the pad life. There is a line down the middle of the pad.. if you can't see that line or it's close to it, the pads are getting low. Or if the metal protrusion on the pad is rubbing on the rotor causing a noise. 40k is good though.
Sidenote: Wolfgang Sealant 3.0 keeps the brake pad dust to near ZERO levels for at least the body panels from what I am currently experiencing. Dont mind the rims being dusted though.
As for the low life of the OEM pads for our cars, keep in mind our cars are HEAVY. 3593 curb weight for the RWD is350 model + 150lb driver, you're already at 3743 lbs. Add 2 passengers and youll be at ~ 4000 lbs. Not including luggage and what not. Takes a lot to bring a heavy vehicle to a stop especially in stop and go traffic and city driving.
Rhambler
01-26-16 07:02 PM
