RCF Wheel fitment
RCF Wheel fitment
Have opportunity to get a set of RCF wheels. Car is 2018 IS350 RWD
OEM RCF wheels have the following specs
Front 19x9 + 50 offset with a 255/35/19
Rear 19x10 +41 offset with a 275/35/19
The rears seem like they will fit just fine.
Im guessing the fronts wont fit? Can I just use a spacer? Or there is no hope?
My goal is to drop it on Tein S-techs and have the wheels just a tiny bit tucked in almost flush to fenders.
If anything you would need a spacer for the front...5mm should do it to make sure you clear the brakes.
If you want the flush look, likely a 10mm spacer would be needed.
Also you may want to reduce the tire sizes...they're a touch on the big side. F:235/35 and R:265/30 (maybe 275/30)
Just my thoughts on it
SFBLUEISF
IS F (2008-2014)
07-15-10 08:11 PM
