high output alternator help
Old 05-23-18, 07:53 PM
Is200tnc
Is200tnc's Avatar
Default high output alternator help
I have a 2016 is200t and i'm looking for a high output alternator to power my system. I haven't been able to find one anywhere. Anyone with help?
Old 05-24-18, 08:54 AM
dmavilia
dmavilia's Avatar
Have you thought about adding a capacitor to help? They basically store power and keep in in reserve to help even out the load on the battery and alternator.
Old 05-24-18, 09:55 AM
Flash5
Flash5's Avatar
Yeah I honestly think this would be a better and easier way not to mention cheaper to help with the stereo system.
Old 05-24-18, 03:48 PM
Is200tnc
Is200tnc's Avatar
Im running a capacitor already. And ive done the big3 upgrade. With the amount of power the amps pull there is still a drop in power. An upgraded alternator would fix this issue.
Old 05-24-18, 03:50 PM
Flash5
Flash5's Avatar
Damn how many watts are you rocking? Lol
Old 05-24-18, 11:49 PM
CriMe
CriMe's Avatar
Have you considered adding a dedicated battery for the system? I went this route instead of the HO alt or cap. Shop put it in the driver side corner of the trunk. Solved all dimming issues completely.
Old 01-04-20, 03:42 AM
Is200tnc
Is200tnc's Avatar
Still looking for high output alternator. Noone i have found makes one for the 2016 is200 . Running a 3000watt wolfram amp and the dual 1 ohm au12 at half ohm load. Big 3 is installed and a stinger spv44 is in trunk. Still too much amp draw for the stock battery.going to install larger battery under hood but really need to find alternator to keep things chatged up.
Old 01-04-20, 09:28 PM
1slowes250
1slowes250's Avatar
1000 farad xs power superbank works well for me. Can't get my voltage past 13.8 unfortunately. I believe it's computer controlled but I do not have any lights dimming. I'm running at Taramps HD 5000 and a 4 channel amp with 2 10's.
RaynArt
Performance & Maintenance
01-08-07 10:33 AM
Neo
Maintenance
11-30-04 06:29 PM
ZeekGS300
GS - 1st Gen (1993-1997)
11-04-04 03:55 PM
alexamparo
10-08-02 06:45 AM
Jmai22
Maintenance
05-16-02 10:44 PM
Quick Reply: high output alternator help
