Converting 7” to 10” Display + Radio/Center Console Upgrade
#136
Are you referring to the aftermarket 10.25" add on screens? Those work with the non navi jog wheel cars. https://www.clublexus.com/forums/is-...x4shop-ca.html
This thread is referring to upgrading the entire OEM head unit/scree/control joystick to a 2017+ unit. You would still need the part of the 2017+ W/Nav harness with the mystery connector since you currently have the 7" screen, along with the 2017+ W/Nav joystick, screen, and navigation head unit.
#137
Do I have to replace the whole center console to adapt the joystick model or can that swap in place of the turn style **** I have now. And also does the 10.25 unit not have a screen built in? As you said above I would need to get the screen and Navi head unit. But I thought it was all one piece. Sorry if I’m crazy lol thnx for responding 👌🏻
This thread is referencing replacing the entire OEM Radio/headunit, Screen, joystick controller, section of the wiring harness, ect with the OEM 2017+ W/Nav unit.
#138
Could you clerify something for me? The interface is a seperate upgrade from the screen (7" to 10.25") correct? Trying to understand this so i can swap what I need to make it work. I can use my stock 17' IS ****, the turn style one like the other thread. Do I need to buy and source a 10.25" screen? Or is that included with the android 6.0 unit?
#139
#140
Absolutely reviving this. Did anyone ever find a solution for the LVDS/GVIF cable that didn't involve finding a factory dash harness? I just need a direct connection between the radio and the display, I won't have an aftermarket android box, unless it doesn't matter that I used the Y cable that comes with those units and didn't use one of the ends.
#141
The radio is not a plug n play swap on the RC...
#142
Hi. I am sorry to bring this old post, but i am searching for the same male socket JAE MX68(The blue square plug). Where can I order from? I searched the internet and the links in this post, but i can not find a site to order from. Can you please help?
91LSupreme
10-07-23 04:59 PM
booja
SC- 1st Gen (1992-2000)
04-05-09 10:22 PM
nysupraman
07-18-05 11:58 AM
