3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#226
This might sound a little crazy but for the first time i sat in the rear seats just to feel how it would be in the IS lol, i was cleaning some stuff back there and i looked down at the seat tracks and i notice on the passenger side the two seat tracks are off center. If you move the seat up and down you will notice it. Not the tracks that are bolt to the floor but the tracks that are bolted to the seat, that ride the outer tracks. As for the driver side its center. I wonder why? is it because on the passenger seat is angle different?
#227
Dumb question -
I have a 2014 Lexus IS 350 F-Sport. Rearview camera does not have TURN Trajectories, I know it was introduced on 2015+ Models.
Is there a way for me to get turn trajectories? Do I have to upgrade a software or buy something in terms of parts? Or is it not possible
#228
Dumb question -
#229
Whats AVS
as this title says, What is AVS?
#230
Whats the purpose of the driver mirror and passenger mirror being placed farther back than other vehicles. It seems like there's a gap giving a little more visibility but is there another reason why Lexus went this route.
#231
chicatemi (10-07-20)
#234
Basically it gets rid of 1st gear so that you won’t lose traction when accelerating from a stop as in the car will try to minimize wheel spin by starting in 2nd gear. It also changes throttle response to get the same outcome of reducing the chances of wheel spin.
#235
This is a common misconception for the 3IS. It does not eliminate first gear in the 3IS. I've personally tested. I believe what it does at most is dull throttle response and possibly upshifts sooner and holds gears more aggressively during throttle input as to not disturb traction.
#237
drives cars
#238
#239
While I have read that it is not true that the car will skip 1st gear, the manual states that it starts in 2nd gear I was just going off that. Whether it does or not I have no idea because I haven’t seen snow with my 3IS. Regardless, the whole point is to prevent the driver from causing wheel spin and increasing grip in snow.
"Snow mode can be selected to suit the conditions when driving on slippery road surfaces, such as snow."
Can you cite the page # and exact quote where it says snow mode starts off in 2nd gear?? Better yet, take a picture of your owners manual?
This has been a common misconception on several Lexus forums for many models. I know older BMWs by default used to start in 2nd gear but not even for snow purposes. Because BMW purposes. lol. but i'm not sure where you're getting that from other than from others repeating it.
I like hardcore facts and evidence!
#240
Dumb question here....want to understand how does the transmission behaves when rolling to a stop? The RPM seems to be at 600-700 and sits in 4th around 30 MPH until I press on the brakes which causes it to downshift 4-3-2. At that the point where it is at 600-700 RPM- is the transmission disengaged which is the reason why it sits at such a low RPM until the brake is applied?
Been having this pop/clunk noise whenever my car downshifts from 4th gear and only in 4th gear. Trying to distinguish between an exhaust pop or transmission issue.
