3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
Lol not a dumb question I have a G37S and it threw me off when I got the IS. I just let it find it’s way, though at first I was super conscious about it and would guide the lever. When I get in my G37S now it feels weird not feeling that zigzag though haha.
I think the zigzag is to try to minimize accidental movement of the lever but idk if someone else wants to input on that. Also might help to know that you changed into a different position since you’ll really feel it when you move the lever.
Really dumb question.
I am not used to this zig-zag gear shift.
My last two vehicles were a G35x and G37x.
Shift lever was straight back and fourth with a slot to go into manual.
1, Whats the the purpose of the zigzag?
2. Do you consciously guide the lever through the zigzag from park to drive? or just kind of let it find it’s way.
also will be switching to full site mode and no more mobile mode ha.
I don't know if I know the answer for sure, but I'd suspect the zig-zag pattern of the shifter is just a stylistic preference. It's also a way of avoiding having a button on the shifter. Both of those elements -- having a button and going straight up and down -- might make it seem like a low-end automatic budget car. I think luxury makes introduced the zig zag pattern a while back. I'm not completely sure though. Just seems fancier. I personally prefer it to straight up and down. I think in the near future though we're going to have digital shifters, **** shifters, or column mounted digital shifters to free up space in the center console.
EoIS300NJ (09-24-20)
drives cars
When I changed my fronts at around 15,000 miles, the very inner on the front tires were bald while the rest of the front tires had about 75% left--a huge waste I know. Now my car was lowered slightly (less than half an inch) so this could've sped the wear up. I got a custom alignment with my toe zeroed out so we'll see this time around if it wears the same. My rears wore much better with 10% remaining (maybe less than 1mm to the wear bars) and inners about bald. That was 21,500 miles. So about every 20,000 miles you'll need a new set of tires, assuming you are running summer tires. You can probably get 30-40k on all seasons.
Dunno about adding more toe-in. That would add wear. The tire is alreading leaning on it's edge and toe'd in on the factory alignment. So it's basically already sitting on the inside, already turned inward, while rolling down the road straight. And the dealer suggests turning it even more inward?
0 toe is optimal for wear under all scenarios.
Maybe the dealer meant camber? (as far as the pressure on the outside in turns)
None of that makes any sense. I'd take dealer advice with a grain of salt. They're usually not that knowledgeable and give very generic "what i heard at the auto parts store" or "things my granpappy used to say" or "things I heard at the gym" kind of advice, in my experience.
Anyway here's an idea of what the inner wear looked like on my old fronts.
I've put 5,000 miles on my new tires w/ 0 toe custom alignment. No noticeable accelerated wear. If they do though, I may just bite the bullet and get aftermarket CABs. They're wildly expensive though.
Anyway lets save this tire talk for the tire thread =) Lets let people ask their questions!
drives cars
Just to wrap up, he definitely mentioned both toe and camber, so I am sure he meant toe.
A couple common noises discussed before, but are they worth tracking down by the dealer?
More harm than good?:
1. Cabin noise: plastic ticking sound near the passenger door. Cabin must be cold to happen.
Either cold winter driving before the cabin heats up, or summer driving after the A/C has been on for a while.
2. Since I bought the car 6 months ago, on a morning start in the garage, there is a mild, sporadic thumping/thudding sound
within the first minute before putting it in gear. Motor mounts? Normal exhaust sound?
2) Can you post a video? What car do you have/what year and how many miles? My turbo IS makes some noises on cold start idle in the morning but there's some wastegate stuff and other turbo noises going on. it's just a car doing car stuff.
I thought the sporadic thudding on start was discussed in another thread, but I can't find it.
I am guessing it is normal, but I thought I would bring it up again in the "Dumb Question" thread.
I thought someone might say......oh yah, I know that noise.
Thanks, though.
Cars usually sound grumpy on cold starts. I wouldn't worry about it.
I was wondering do our 3IS have any system within our car that will tell us that something is wrong, such as your headlight bulb, taillights and other lights.. are burned out or not working???
Like my Audi and Benz anything that is not working or wrong, the system will pop up a message on the dash stating what and where is malfunction. Like euro cars with Can-Bus system. Any little thing you change if the system does not recognizes it, it will throw a fit.
Also what program or device Lexus use to scan and check our cars with?
Audi uses VAG (vcds) and Benz uses Star
Received 1,737 Likes
Yes the vehicle is equipped with a burnt out exterior bulb system.
And Techstream is the software that is used to scan Lexus/Toyota/Scion.
drives cars
This is probably a dumb question, and I am pretty sure I know the answer, just want to see what you guys think.
https://photos.app.goo.gl/LjJ8Zp1K9aSUjikf7
So I was going for a spirited drive yesterday (hey, it was Sunday after all ) and washed the car afterward. I noticed the brakes were pretty hot. While cleaning the wheels, I sprayed water onto the brake disc of the front right wheel. The water instantly turned to steam.
So I showed this to a friend and he said "maybe the brakes are warped?" I said, no, it was because I was actually using them . So I figure it's normal for them to get hot if used a lot in a short period of time. Any thoughts, confirmations?
