3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#841
Hello, I'm new here and ready to ask a dumb question about the Dynamic Handling Package.
For anyone that has driven/owns the 2021 F Sport, is there a big difference between Sport and Sport +? I ask because the F Sport comes standard with the Sport setting I believe, but for Sport+ and "dynamic suspension" (which I am guessing is some kind of magnetic shock absorber setup) you have to have the Dynamic Handling Package. I am also confused as to what the real difference is. Is the ECU tuned more aggressively, or does it just change the shift points? Does any of this even matter if in manu-matic mode? Are the shocks non-adjustable for the models without the DHP?
I would get the Dynamic Handling Package, however that option doesn't let you choose the option for black/white seats, only black/black and red/black, which is a huge bummer as I like the look of the white seats. The rims don't really matter to me as I'd probably swap them anyways.
Thanks!
Thanks!
#842
I just know on my 14 with nav all that takes place in the settings within your Infotainment.
I'm sure highly likely the same with yours..
You can change the number of preset radio stations you have, clear the preset data, or if you just want to override you don't have to go into settings.
Youll find what you need in the audio settings in there. When I bought my car it had an absurdly high amount of preset stations so I limited it down the like 12 I think I reset them all to what I wanted after clearing the stations that were in there.
Do you know how you actually cleared the stations? That is the part I am not seeing or finding in the owner's manual or once in the radio settings.
#843
drives cars
Thanks!
Thanks!
The throttle mapping between Sport and Sport+ is probably similar, though I haven't driven anything newer than a 2018. I didn't notice any difference in throttle between Sport and Sport+ at the time. With manual shift mode, I have never noticed a difference across the various modes either.
#844
How Do You DELETE &/or Remove Preset Radio Stations?
Time for another dumb/stupid question after googling, reading the manual, & searching this forum... does any1 know how to Delete &/or Remove Preset Radio Stations, as opposed to just overwriting them? Thx!!
#845
#846
On a different note does any1 know if there's a way to MOVE preset stations up / down?
#848
Headlights
I've been curious about this but was never able to figure it out on my own.
I've seen some early 3rd gens (2014-'16) with both single projectors and some with dual (in single housing) projectors. I've seen this variation among both F Sport and non F Sport models. Can anybody clue me in on why this is? See image/attachment for reference.
#849
Received 1,738 Likes
Depending on package and country of destination depends on what you got.
#850
#851
#852
#854
drives cars
If you have an AWD IS F Sport, you get the same brake pads as a non-F-Sport. Only the RWD models get semi-metallic pads, which have accelerated wear.
