3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#976
Are the ventilated seats in the 3IS/3.5IS linked to the fan speed and/or the AC setting? That is, if I run the ventilated seats without turning on the fan, they're pushing air but if I turn the fan on, will it make the airflow faster?
Also, if I turn the AC on and set it to a lower temperature (ie. LO) will that cause the air circulated in the ventilated seats to become cooler as well?
#977
drives cars
As for the fan speed, they seem to operate independently of the HVAC system.
#978
Short answer - no. The ventilated seats do just that - they merely provide ventilation to the seat bottom and back. So, whatever air is in the car will be used. For this reason, I like to let the car cool down a bit before turning them on.
#979
#980
https://www.clublexus.com/forums/is-...nted-duct.html
GNS (10-11-21)
#981
If you want to increase the airflow to your ventilated seats, read this entire thread:
#982
Here is a perhaps not so dumb question that I didn't see the need to make a thread for... Can a transmission oil cooler be fitted to both 6 speed and 8 speed transmissions? I saw a 2IS thread (https://www.clublexus.com/forums/is-...installed.html) where a guy screwed some fittings into the two holes beneath the OEM heat exchanger. Apparently the oil cooler hose fittings for the 2008-2013 Sequoia and 2007-2019 Tundra will screw right into that transmission. Namely what I would like to know is if the heat exchanger holes are still threaded on the A760H and AA81E. I would assume they are as both are relatives to transmissions with threaded holes (I.E. the AA80E, and the A760e).
#983
Here's yet another dumb stupid question but can't find any answers online...
Going away for a few months, and a rear tire has sidewall leaking issues (< 0.5 lbs per day), so I jacked up the car at that one tire.
Leaving the car jacked up at one wheel for a few months is completely harmless right? TIA !!
#984
Received 1,737 Likes
Regardless the tire will be flat after a few months...it will probably be flat in a few weeks.
If you're worried about the tire going flat and the weight of the vehicle being on it, consider the car isn't going to be moving...it also sounds like you need a new tire anyways.
If you have a sidewall leak that bad then the tire is already compromised.
#985
There was an entire thread exploring the possibility of installing a transmission cooler...it basically came down to one question, "Why?". Which there wasn't a legitimate answer for.
I guess you may want to consider the same question.
There is one member on here with a twin turbo IS350 RWD making almost 600rwhp, and he's running the stock transmission. Obviously he's not driving it like a little old lady.
The holes may be threaded, and for the time it takes to jack the car up and remove the 3 bolts holding the cooler on, you could find out quickly if they are and what size, thread pitch they are also.
Chances are if they are threaded it would be the same size as the 2IS holes since the trannys are in the same family as you mentioned.
#986
Here is a question I wonder if someone knows?
Does anyone know what was done with the 3.5 V6 that changed the hp and tq ratings from the earlier years to the newer years rating from 306hp to 311hp. I know the engine code is different, but was it the intake, cams, exhaust? Anyone know exactly?
#987
Any idea which kit this is, or is it a custom setup? I'm starting to think that I will have to do this after the warranty is up, in order to have the turbo AWD IS350 that Lexus won't make for me lol
#988
drives cars
#989
GNS (10-14-21)
#990
Most definitely all custom. https://www.clublexus.com/forums/is-...rbo-is350.html
