3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1021
IS 350 RWD models have the 8 speed too. In fact, the only RWD cars that don't get the 8-speed are the 2014-2015 IS 250.
#1022
When you change the battery, does the maintenance interval get reset?
Just curious because I always just took a picture of my mileage when I changed it before so I would know exactly when I did it. But last time I decided to just use the trip odometer. My battery was getting weak, so I swapped it out and my trip odometer reset to zero.
#1023
#1024
Its not really that big of a deal since I recently changed the oil and know I only have a 1,000 miles on it at best. Just a standard dumb question for this thread lol
Jazzrock (12-25-21)
#1025
I have replaced mine before but never really noticed it having reset the trip odometer or maintenance before. But this time it did reset my trip odometer and I was using it to track my oil change. I reset the maintenance at the same time, just curious if that may still have the correct timing on it.
#1026
Jazzrock (12-26-21)
#1029
potential new owner for aIS300/ 350.....
in a nutshell what are the major to do's that arent covered in the service interval that you'd need to / expect to do for a v6 from 50 to say 140k ( loking to buy a used one 2015 to 2018)
I'd expect suspension, new cats possibly, uca and lca, ( no timing belt so good on that)
Any other parts to be aware of that would sneak up on or unique to this platform?
#1030
Lexus claim that the transmission fluid is a "lifetime fluid", but many owners have reported issues with the transmission that could only be resolved by doing a fluid change. So you may keep that in mind. Some have recommended doing that every 40-50k. Honestly, outside of the transmission fluid, you should be doing your standard maintenance as per the service schedule and be just fine. Keeping an eye on suspension components, as you have alluded to, is a good idea with just about any car.
#1031
Welcome.
So.... is this engine/ platform.... "reliable" low cost... compared to say my Audi at 170k?
#1032
I mean, if I really stretch, I can think of an odd thing to go bad with the engine. A friend recently had his spark plug sleeve go bad on cylinder 5 in his 2IS 350. So, the engine burns a lot of oil. But, it can be fixed. And, this is an engine with just over 200,000 miles that has seen a lot of hard driving.
Overall I'd say to just make sure the car you're purchasing has a clean history and up-to-date maintenance and go for it!
DoDoDozer (01-01-22)
#1033
From a owner of every German nice car from the past, I also say what pre owned German car does not need expensive repairs or does not have a Oil leak. Nice car but as soon as you spend $?k and say ok now I'm good, $?k comes along next needed for something else shortly. I would only least a German car under Warranty. From years of past and many owned I would never buy again.
#1034
In good condition and serviced no one has even near the issues any Audi can have. Its what Toyota is known for.
Are the current costs of is350 2016=2017ish crazy high now or just normal inflated due to "covid times" In the GX470 world they are crazy high, almost 30-40%higher vs an expected 15% higher
Any regional areas lesser / higher in cost? ( I am buying from a non rust belt state... dont want frozen borken bolts/ rusted wheel fenders, The GX is from TX a fly and buy/ drive)
#1035
Sadly i'm with you. I like working on my cars. I enjoy it. Audi will kill you if the mechanic does everything. I have way too many hobbies and with 2 young kids, even less time to spend time replacing the camshaft or such.replacing HPFP, plug wire harness, coil pack replacement, oil pump vacuum seal etc etc... I've saved easy 3k in mechanic cost but lost on the stress/ time loss spending on kid time.
Price wise I shop patiently. Know what I want, color, equipment condition miles, then buy when I see the best price with that. I also quit doing the buy and drive back. Deliver with less miles and my time. Don't buy into a nice trip to drive my new car. Will own it long enough to do that.
