3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1037
drives cars
Traction control is mainly just associated with making sure the wheels are actually putting power to the ground and moving the car instead of spinning in place. It does this through the use of sensors, such as wheel speed sensors, and cutting engine power delivery to maintain traction. VSC is more about making sure the car is following its intended path and not sliding around. It does this by using various sensors to detect where the four wheels of the car are going and, for example, applying brakes when needed to straighten the car out. Of course, you can be sure these two systems are integrated.
As far as disabling these systems goes, unfortunately, it's a bit difficult to disable anything without turning everything off. For instance, you can temporarily disable ONLY traction control by pressing the TC Off button. However, it will return after a short period of time or after a certain speed is reached. It's possible to disable BOTH traction control and vehicle stability control by holding down the TC Off button for a couple of seconds while stationary. Because the VSC system is integrated with things like emergency braking, those features are also disabled when VSC is disabled. Curiously, this is also the only way to get the engine to ping off the rev limiter unless you also have Sport+ mode. This makes me curious as to whether Sport+ mode also causes a reduction in either traction or stability control - if so, it isn't telegraphed to the driver.
#1038
Technically, Sport+ would make the VSC and TC more lenient and slightly less intrusive, as would regular Sport mode. There is a maneuver to disable both VSC and TC which is known as the "pedal dance". Basically, it puts the car into a sort of hoonigan mode. There are a few videos of that on Youtube. Just beware that disabling VSC and TC can make a car completely transform, whether that's from an understeering behemoth to an agile racecar or an agile racecar to an oversteering buffoon.
#1039
drives cars
FWIW, I haven't noticed any difference between the pedal dance and having TC fully off.
#1040
Well I can't completely say Sport+ lowers the VSC/TC intrusiveness but, logistically, it should, as the name is 'Sport' or 'Sport +'. As far as I know most German manufacturers do this so I would assume the IS is the same.
And from what I've heard the pedal dance turns VSC and TC fully off, as in truly fully off. I remember somebody mentioning that turning the VSC/TC off using the button will turn it off for the most part until it detects that you're pretty much in an oh crap moment. Sort of like the Expert mode on the RC F (though that does more). So basically you'd really have to be doing something really, really stupid to get the VSC/TC to activate, if my hypothesis proves correct. Just remember to take this with a grain of salt.
#1041
drives cars
Furthermore, with respect to the Germans, I think we all know Lexus marches to its own drummer... Besides, in my wife's BMW, the way to reduce TC and ESC is pretty explicit. There is a reduced TC mode called M Dynamic Traction Control, then there's fully-off. Putting the car in Sport mode doesn't seem to do anything to the TC or ESC. Just an example.
Yri (01-03-22)
#1043
So I'm not sure if this is the right place for it or not but I thought I'd ask and get y'alls opinions. So I bought a 2022 IS350 with DHP two weeks ago exam and I'm still in the process of learning the car but had some questions about some things I've noticed and I'm not sure if they are an issue or not.
1. Rear defroster
1. Rear defroster
So today my rear glass had a bunch of dew on it and it was a bit cold (for Florida standards) so I got in the car and turned on the heated seats & steering wheel, and then turned on the rear defroster. I sat in the car for like 10 minutes to let the car warm up and I noticed that it had barely defrosted anything! I got out and touched the outside of the glass near the defroster lines and it was very slightly warm. On the inside though, the defroster lines were warm. Is this glass thicker and it takes a while or was the fact that I also had the seat warmer and steering wheel warmer the cause of the issue? Perhaps @Sasnuke or @flipside909 with the electrical diagrams may be able to chime in. Maybe those functions are under the same fuses/circuit?
2. AlignmentLast Saturday I took my car in to Lexus to have the alignment checked because I noticed that the steering wheel was slightly off center when the vehicle was driving straight. They checked the alignment and found the front and rear passenger toe was out of spec and they adjusted it. The steering wheel is straight, but I still feel the car pulling ever so slightly to the right. The service advisor informed me that these cars tend to favor the crown of the road because of the low profile tires. I did some research on it and I found other IS owners with similar issues in the past and one suggestion one person said to confirm if it was the crown, was to drive on the opposite side of the road (obviously when nobody was coming down it lmfao) and see if the car then pulled to the left. I did that with my car and it did in fact pull ever so slightly to the left. Would this then be something that can be considered "normal" and I should just ignore it?
#1044
^^ I'll let the expert chime in on #1.
On point #2, there is some truth to the car following the road so that makes sense to me. What I have also noticed every time I buy a new car, and maybe it's in my head but I find for the 1st 1000 km or so, this is a bit more pronounced and then seems to go away and not sure if it is partially related to the new tires and almost as if they need to "wear out to the road" if that makes any sense...Can't explain it well....If you had an alignment done and all is within spec, I wouldn't worry too much for a little while and see if it gets less noticeable. Also, try and find different roads to drive it on and see if that happens as well
TipsyTonio (01-14-22)
#1045
Your insight on question #1 might actually be really helpful since you basically live in the North Pole. What has your experience been with the defroster? Slow or fast? Or never used it because your car is a garage queen
#1046
^^ Well, I have found the Lexus a bit weak on the heated steering/seats when I did use it as with the defroster but again, the odd times I have used it was in the late fall or early spring when we would get colder conditions. The part I wanted the experts was your part of the diagram as I wouldn't have that at my finger tips.
My Spark (GM) is amazing with heating by my Elantra is also very weak, especially the rear defroster and heat in the cabin - The heated seats are fantastic though
#1047
Received 1,737 Likes
Right, some people mentioned the same thing as well; with time it got better. I have the print out of the alignment and everything was set correctly so I'm not too concerned by it. I've tried it on a bunch of roads and on some it is more pronounced than others.
For #1, it really depends on the size of the water droplets.
For us here, the "frost" is really a fine layer of moisture that the defroster will clear in minutes. But when you talk about actual water, then that means it's not cold enough to be frost, therefore the defroster is likely not going to do much, if anything.
And yes the inside of the glass will feel warmer as the defroster lines are closer to the inside of the glass than the outside. Realistically the frost is usually built up on the inside, so this is where the defroster tries to make the most impact when operating.
Without actually seeing the vehicle in action for #1, I'm going to assume it's also normal.
For a place like southern Florida I can only see defrosters being useful in some very specific scenarios, considering the weather you get. For us in the North Pole it wouldn't be uncommon to use the defrosters several times a week, if not daily, during January and February especially.
The following 3 users liked this post by Sasnuke:
#1048
![In Love](https://www.clublexus.com/forums/images/smilies/inlove.gif)
For #2 that's normal.
wthrman2 (01-14-22)
#1049
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/596bfdfd_88c3_47cf_ba57_bbbb1e6b1f19_cee3100bdd90f8010f4710d23a5e619a8df64d7d.jpeg)
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/be54c695_289b_458a_a8a2_d077cad228e8_d92d84cbab1179b933f25743116f746dfbed1cd5.jpeg)
#1050
^^ I doubt water would get in. I would ask the dealer next time you are in and see what is involved to have repaired and then decide if its worth it or not. I am surprised that it can't just be pushed in but its hard to tell for sure....To me, it is more of a cosmetic thing than anything
