3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1067
thank you regardless!
arentz07 (01-14-22)
#1068
So, yeah looks like it's a similar story with my window. I never noticed that before. Good eye.
TipsyTonio (01-14-22)
wthrman2 (01-14-22)
#1071
Oh I forgot about my third “issue”. There’s this weather stripping in the rear drivers side window that does not want to sit flush with the window frame! I’ve tried lowering the window to push it and everything. Nothing. I’m considering mentioning it to the service department but I really don’t want them to have to take apart the door panel on a car with 400 miles. Would this require even removing the door panel to have it replaced? And I guess my main concern, can water even get in as it is? What do y’all think?
TipsyTonio (01-15-22)
#1072
My wife's CT also has issues with the weather stripping on the rear driver side window. It is pushed into the door and permanently deformed. I asked the dealer about it and they said that's cosmetic and it would cost me to replace. Different place as you but similar idea. No amount of strength can bring it back to shape and out of the jam. I thought I was the only one.
arentz07 (01-16-22)
#1073
The following 2 users liked this post by wthrman2:
arentz07 (01-18-22),
TipsyTonio (01-18-22)
#1076
They may even want to take pics and send to HQ quality control department so they can see what the issue is before actually making a repair attempt.
If enough people have this issue, which is possible, then Toyota should look at correcting it.
You can simply let the advisor know you are bringing the issue to their attention, not looking to have your car ripped apart at this time to fix it.
If enough vehicles have this issue then HQ can find a guinea pig to use for investigation and repair attempts...doesn't need to be your car.
The following 2 users liked this post by Sasnuke:
TipsyTonio (01-18-22),
wthrman2 (01-18-22)
#1077
I would bring it to their attention so that it can be documented on the work order...now there will be a record of the issue should they question it later on.
#1078
Also, each car is tested for water leakage at the end of the manufacturing process for quality checks. I'm pretty confident that misaligned weather strip is doing its job keeping water out. Just tell your service advisor of things that look to be of defects and they will check out out for you. It's good to build rapport with your service dept. They will take care of you in different ways later down the road.
#1079
This must be your first new Lexus lol. These cars are built pretty well from the factory. Even if they remove the door panels, the techs check their work and test everything before closing out the ticket.
#1080
