3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1081
Lexus Connoisseur
First Lexus, but not first Toyota product. And I've taken cars in for recalls and left with broken components. Theoretically, yes, the dealer will have to replace anything they break, but what if it develops a rattle? The door panel I'd consider, but removing the window is a big no no for me especially since that would require peeling back the plastic film behind the door panel, and I already know they're not going to glue it back properly because nobody is going to see it.
TipsyTonio (01-18-22)
#1082
Received 1,737 Likes
The moisture barrier is attached by silicone adhesive, removing and replacing it is no big deal as you're not breaking any kind of major seal. You really have nothing to worry about, and they will put it back together correctly. This is Lexus we're talking about, not a Toyota dealer.
Obviously the ideal scenario is to remove and replace the moisture barrier without any damage, but even if it was slightly damaged, any water that gets in the door will drain out the bottom through the drain holes...this is independent of the fact if the moisture barrier is perfect or slightly damaged...or missing.
I probably would have said, "This is Lexus we're talking about, not a Tesla dealer."
The following 2 users liked this post by Sasnuke:
Jazzrock (01-18-22),
#1083
Lexus Connoisseur
Actually, the moisture barrier is held in place with Butyl Tape, so it's actually reusable to an extent if you are careful removing and reinstalling it. It doesn't harden, so it's always pliable.
- 3M Black Super Weatherstrip Adhesive Tube - 5 oz. - 08008
![](https://tooldepot247.com/pub/media/catalog/product/cache/e4d64343b1bc593f1c5348fe05efa4a6/7/1/71rcgv6ll-l._sl1500_.jpg)
#1084
You can clearly see from the pic below it states Butyl Tape for item #7.
Every door panel I've ever taken off a Toyota or Lexus has had Butyl Tape holding the moisture barrier in place. In Winter it's firm and thick like Tofi and in Summer it's much softer with an almost tar like consistency.
I don't think I need to comment on this any further. I would suggest that the term "tape" is misleading as it's not really "tape" in the conventional sense that we think of, but nonetheless that is what the product is called.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/707x927/bt_da9cecd993684f48802cf62a8f1bd1c6dab0d8e3.jpg)
TipsyTonio (01-19-22)
#1085
Lexus Connoisseur
You may want to reach out to your contacts at Toyota/Lexus and ask them to correct every repair manual they have then if you're 100% sure it's not Butyl Tape.
Regardless of the tape or adhesive used, it should be cleaned up and replaced if a door panel or the door assembly is replaced.
#1086
Have to replace the struts and shocks on my 16' IS300 FSport soon. Looking it up by VIN, Lexus gives me several options including AVS for the rear shocks but just wanting to confirm that from my understanding only the 350's came with that option? When I look at the front struts on the parts fiche, only gives me one option for L&R and doesn't mention anything about AVS on the description, so again my assumption is that I'll need non AVS rear shocks but well again just wanting to confirm. Yes, I did use the search button but didn't come up with anything searching under AVS and or Adaptive Suspension in the 3IS forum, thanks in advance!
arentz07 (02-07-22)
#1088
Heres your part number: 75443-53270
Papa Joe can correct me if I’m wrong
Yaroze86 (02-07-22)
#1089
drives cars
@Yaroze86 Congrats. I am not sure how I feel about the removal of the F Sport badge, but I sort of suspected it based on how the IS 500 doesn't have one either.
I think it'll simplify things going forward with the whole F Sport Style/Handling/Performance lineup - they'll only need to make those differently-colored fender badges instead of the ones for the trunk lid as well.
Yaroze86 (02-07-22)
#1090
Panoramic View w/ Cross Traffic
DHP Package
Triple Beam Headlights
Navigation/Mark Levinson Package
Moonroof
All Weather Mats
Door Edge Guards
Trunk Mat/Cargo Net/Wheel Locks
The following 2 users liked this post by Yaroze86:
arentz07 (02-07-22),
TipsyTonio (02-07-22)
#1091
Probably covered before, but not coming up with any search results. Does our car have the ability to program the auto-turn signal feature to blink five times instead of three? This would be for a 2020 IS350 F-Sport w/o nav. I could have sworn I read about it years ago, and I do see the manual list "5 blinks" as an option. Just don't see any instruction on where to go in a menu or how to do it. Service advisor says he can't find anything either. Thanks!
#1092
I was but I talked myself out of it. It's more a car then I need. I would feel bad about driving a Serialized numbered car as a daily as well. I have the AE86 for fun drives.
DHP Package
Moonroof
All Weather Mats
Door Edge Guards
DHP Package
Moonroof
All Weather Mats
Door Edge Guards
#1093
EDIT #2 - http://s3.amazonaws.com/lexus.site.t...U/OM53E98U.pdf
P 399 (section 8-2) customization by Lexus tech
#1094
wthrman2 (02-08-22)
#1095
