3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
Old 03-11-23 | 12:34 PM
  #1186
PersianOne's Avatar
PersianOne
Originally Posted by arentz07
0w20 is the recommended oil for your engine. You are good to go there.
Personally, I wouldn't bother with the spark plugs for now. I'd give them at least till 40k before I replace. As you said, they're affected more by use than by age.
Yeah that seems logical, I'll hold off on the spark plugs till 40k. I think my immediate next "mod" will be to replace the LCA bushings with RR racing ones. Just to be preemptive seeing as the biggest issues are the LCA bushings and the AMP going out (mine has been flawless so far *knock on wood*).
Old 03-18-23 | 12:08 PM
  #1187
PersianOne's Avatar
PersianOne
Looking to get brighter hi-beam bulbs for my is350. Is this simply a plug and play type deal with just replacing the bulbs or is there more to it? Also, any recommendations for the brand?
Old 03-18-23 | 04:28 PM
  #1188
arentz07's Avatar
arentz07
Do you have the dual LED headlights? If so, I believe the bulbs themselves are not replaceable.
Old 03-19-23 | 02:06 AM
  #1189
PersianOne's Avatar
PersianOne
I’m not sure. I have a 2014 IS 350, all the lights are stock.
Old 03-19-23 | 09:04 AM
  #1190
arentz07's Avatar
arentz07
https://www.clublexus.com/forums/is-...l#post11181369
Check that post and let me know what you think. You can just look at the lights and see which ones you have.
Old 03-19-23 | 02:59 PM
  #1191
PersianOne's Avatar
PersianOne
Dang, I got the LED dual projectors since I do have an f-sport. So not as simple as plug and play huh?
Old 03-19-23 | 03:30 PM
  #1192
arentz07's Avatar
arentz07
Probably not. Are your high beams not working right? I always thought they were pretty good.
Old 03-19-23 | 03:51 PM
  #1193
PersianOne's Avatar
PersianOne
They work, just seems a little low on output to me. Maybe I'll get around to installing some fog lights instead.
Old 03-20-23 | 05:54 AM
  #1194
bgross88's Avatar
bgross88
Quick question that might have been covered previously. My car is a 2016 IS300 AWD F-sport. I just returned from a 3 week vacation; car wasn't run/started during that time. When I got home, car started right up--no battery issues/etc. However, the radio/navigation/map system went through a system reload on start-up. I forget the exact wording on the screen. But basically, it rebooted/relaunched.
Is that normal? I remember reading that will happen when the battery is dead/replaced, but I had no power interruption. No issues after reboot, but I'm curious as to the reason.
Thanks...
Old 03-24-23 | 12:41 PM
  #1195
arentz07's Avatar
arentz07
Thanks...
To me, doesn't seem "normal", but if all your settings are still there, etc. and everything works, I guess you are fine? Might be worth seeing if it happens again.
Old 03-24-23 | 01:37 PM
  #1196
Jazzrock's Avatar
Jazzrock
Thanks...
Is your battery the original one? If so, probably time to replace it.
arentz07 (03-26-23)
Old 03-27-23 | 05:27 AM
  #1197
bgross88's Avatar
bgross88
Yeah, it's original; I'm going to replace it to be safe.
Old 03-27-23 | 05:46 AM
  #1198
GNS's Avatar
GNS
Thank god for this thread because I'm about to post some really simple questions. Recently picked up a 2014 IS 350 F Sport with 26k miles. The previous owner babied this thing but I'm still trying to get all the maintenance done and be preemptive (part of me thinks I'm overthinking some things). I've done the front rotors/pads, alignment, and got an oil change and full inspection (topped of fluids/checked all levels) at my local Lexus dealership. Everything came back with no issues.
Now I'm reading up on spark plug replacement, I see some threads saying 40k and others saying 60k then some saying to just run it until you see noticeable affects (lower gas mileage,etc...). My question is, should I worry about the spark plugs right now or have them changed for peace of mind? 26k miles isn't too high but the car is a 2014 but I know it really depends on the mileage. I usually get like this when I buy a car, I want to change everything so I know it's brand new and I have nothing to worry about but it can be a burden because as the old saying goes "if it ain't broke, don't fix it."
Also, I see the dealership used OW20 synthetic oil instead of 5W30, is this fine? I saw a thread where it said "0W20 is only recommended for 2014+ IS350 engines." Any input is appreciated, thanks!
Personally, I believe that 0W-20 was specced for EPA reasons only. 2013 and earlier models have the exact same 2GR-FSE V6 but their manuals recommended 5W-30 (you can search the manuals online and go to specifications in the back).
Still, 0W-20 should be ok if you change it every 5000 miles or less. I run 5W-30 Motul Eco-Lite in my IS350 because it's a true full synthetic and it has an additive that keeps the metal coated even after the oil has drained into the pan (Motul gives it a specific name, Ester Core or something).
Old 03-28-23 | 09:05 AM
  #1199
rVague's Avatar
rVague
I have a 2023 IS 350 and noticed that in sport mode it will shift into 7th gear but won’t go into 8th unless I’m in manual mode. Is there a software fix for this?
Old 03-28-23 | 09:27 AM
  #1200
arentz07's Avatar
arentz07
That is what Sport mode is designed to do. If the transmission has 8th gear engaged at lower speeds, the engine will be spinning at low RPM. Lower RPM means less power available to you. If you've selected Sport mode, you are asking the car to give you enhanced performance - and being at a very low RPM is not good for performance.
So, to answer your question, no. The car is working as intended! Just enjoy it.
The following 2 users liked this post by arentz07:
rVague (04-02-23), swaangin (03-28-23)
Quick Reply: 3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
