3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1216
Rotating tires mostly just spreads the wear to all 4 tires instead of just two. Braking west, cornering wear, acceleration wear.
Also I’d be at least a little concerned about liability in case there was a crash deemed to be caused by loss of traction. If you fishtail causing a crash on tires more narrow than were the approved size originally fitted to your car, your insurance might try to deny coverage. “Was the car modified?” is a question insurance companies will ask.
LaZeR (04-17-23)
#1217
I briefly owned a '06 IS350 several years ago. I sold it. One thing I didn't like about the car was the different size tires on the front and the back. I understand the current gen IS's are the same way. How do you manage the wear of the tires when they can't be rotated without putting on hard tires or driving like a grandmother?
As suggested, you can rotate side to side. This helps keep the wear even on the two same size tires. A rear drive will often wear the right rear tire faster as it is the more unweighted side under power and has less pavement traction. But who says you have to change the front and rear at the same time? You'll be going into the tire shop for a rebalance of your tires every 5,000 miles or so anyway, so you can just get the two you need at that time.
#1218
drives cars
However, the better tread pair should ALWAYS go on the rear, but this described practice can sometimes be challenging with a staggered set up.
#1220
Is it normal to have such a hard downshift from 2nd to 1st gear when in manual mode? My rpms won't even be that high yet the downshift is so harsh as to what I assume is the engine braking. Nothing sounds wrong, it just feels very sudden even when going slow and I make the shift from 2nd to 1st. Maybe it's just normal though.
#1221
drives cars
I simply avoid downshifts into first.
PersianOne (04-19-23)
#1222
After months of waiting and finally having our (me & wife) 2023 IS 500 build at port and reserved last week we had to sadly let it go. Budgeting for a new place, moving, and a baby on the way convinced us to settle on the IS 350 F Sport for now. I'm sure other first time parents can relate. I'm asking this question here regarding the panoramic view monitor option because my dealership isn't 100% sure regarding its configurations and unlike the 500 the 350 requires much more adding of options and accessories. Does the Panoramic View Monitor Option come with the larger 10in display (on its own) or is purchasing Navigation the only way to get the larger display?
Basically, Does Panoramic Option (without Navigation Package) = 8 or 10 in display?
Thanks in advance,
Thanks in advance,
#1223
@albertcado you mean cozza SAVINGS of around $10,000 +/- ? Wise Choice IMO.
#1224
Yes yes will definitely be saving more than 10k and also with fuel efficiency. Currently driving a manual mustang gt and the cost on fuel is quite high especially with a lot of city driving. Do you by chance have any insight or knowledge on the question I had regarding the Panoramic View Monitor screen?
LaZeR (04-20-23)
#1225
Not sure how to describe it exactly, but the gear ratio of 1st gear is 4.60, 2nd is 2.72, 3rd is 1.86, 4th is 1.46, 5th is 1.23, 6th is 1.00. So you can see the spread between 1st and 2nd is quite high and as the gears go up numerically, the spread is much narrower. So the jump up, or resistance pull down, from a lower gear is much more likely to be felt and is much more of a jolt on the gears. Point here is you are putting a much more strain on the gears (and actually the whole drive train and tires) when you force a down shift manually.
Probably would not hurt it if it was done occasionally, but there's much more chance that continuing to do it could be harmful. I don't know what that number of times would be, but probably beating it like on a race course would be more taxing.
PersianOne (04-23-23)
#1226
Thanks in advance,
Thanks in advance,
#1227
drives cars
#1228
#1229
The F sport air filter from the 2015-2018 350 should fit in the 2023 350s air filter box since they're similar engines correct? Also would the 2023 also fit the air box lid with the graphic on it?
part # for filter PTR0353141AA
part # for upper air box lid PTR0353141AB
#1230
drives cars
I would think so. Engine bay is virtually the same.
