3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
#1321
Bearcats98 (03-20-24)
#1326
drives cars
Most likely, it'll need to be re-chromed or else replaced. I think the cost of either option will be pretty high... might as well replace if you want them looking like new again.
#1327
I was afraid that was going to be the answer. US market. And since they are making it very hard for vendors to chrome; the cost to rechrome is pretty high and walks right into your statement. Oh well. Ill ride em out for now and when I come due Ill rerim/tire and use these as winters.
#1328
I seen a guy do a BBS matte black wheel and I swear I couldn't tell a difference unless you took a flash light and looked 1' away, then you could barely see the paint difference.
Dancingrobot (04-07-24)
#1329
drives cars
There are wheel repair guys that work magic. I would call a few Lexus dealerships and ask the service guys what rim repair company they use to fix their cars. Usually some scrub will come out to your house for $150 or less, you'll be anxious but man, they won't be scrubs no more because some do amazing work with paint. They'll sand down the bad areas and repaint to match if you're looking for a cheap route.
#1330
I've been through trying to repair one of the dark chrome wheels, and it did not turn out well. It was very obvious. The chrome finish is like a mirror - no paint is going to be able to replicate that effect. I ended up getting it replaced. Thankfully the damage wasn't my fault, so the other party paid for it.
#1331
Yes, there is a very good wheel shop near me. They do GREAT work (used before). However (isn't there always a "but"?) the caveat is that they don't do chroming of any kind due to licensing and EPA issues and he states that getting a proper finish was difficult from a quality perspective.
I like the color of OEM rims and shape is "ok". So for 200 a rim to get em back to stock was a cost Id spend. I dont like em enough to buy brand new. So I guess Ill start saving and when I have enough start looking for new rims.
#1333
drives cars
I think I used to keep them in those pockets with my 2016 IS. As long as it's a pretty thin twisting shade like you'd get at Auto Zone, it should be fine.
#1334
Here's my doozy. 2005 ES 330. 251K (Still going) Mysterious sound coming while sitting in the cab D seat. A low roar that can only be heard while in car. Thought it was the flex pipe so I took it to a muffler shop that does it regularly. No that wasn't it. Thought it was the exhaust seals. Replaced them and no difference. Checked for intake leak with carb cleaner. No response.
Thought it could of been P/S pump. No Squeal.
Sitting in the front seats the roar comes from directly behind the dash. You can hear it from the engine compartment. Just for giggles I popped the rear seat and tried to listen to the pump. Couldn't get to it. I listen to the lines under the car and head sounds from one of the four fuel lines. Wondering if the EVAP cannister was going bonkers but the car but according to what I found there are no symptoms of it being bad.
I took it to two more shops. Nope. Couldn't find it.
Any suggestions would be great ya'll.
OOps sorry yall. Wrong area. Not sure how to delete it.
#1335
drives cars
