Drive Mode - Temporary Shift Range
Anyone use this mode?
While in drive mode, we're able to select a top / maximum gear the car will shift into, temporarily. Do this by using
the paddle shifters and selecting a gear 2-8 (2-6 on six speed).
Nice for downshifts when I dont want to be in manual mode. However, would be even nicer if it worked as it seems it's supposed to. When in traffic, I dont need the car shifting up to 5th gear at 25mph, but rather would like to limit this to say 3rd gear as I know I'm about to slow back to 5mph.
However, the problem is the after pushing the accelerator for 4 seconds it comes out of this mode, rendering it useless for my purposes. I guess it's the "temporary" part that's got me baffled
Anyone use this and find a good purpose for it?
The new 8 speed transmissions use "m" manual mode and the 6 speed transmissions uses "s" sport mode. The sport mode chooses the best gear for what your foot is doing and limits the top gear to wear you set it. It is basically a gear limiter. No real need to shift. On the other hand, the 8 speed transmissiion Manual mode "m" is whatever gear it is in until you decide to change it.
This mode is similar but used while in Drive (as described). Shown on the dash as gears D2, D3, D4....as opposed to manual mode M2, M3, M4 etc.
Aahh so that's what it's for lol..
I've always thought that it's some half-assed manual mode that doesn't work very well.
However, it also doesn't work the way you described - I think it's more for letting the car know what you want to do next. For example, if you're cruising at highway speeds and then shift down to 3rd for overtaking, it does that perfectly fine. When you then shift up to 6th, the car knows that you will return to normal cruising speed and will eventually shift to 6th (when it's the best time to do so). If you would shift up to 5th, it would think you're slowing down a bit, so it stays in 5th for a short while. If you don't slow down however, it switches to normal mode and changes back to 6th again.
Yeah I almost never use the paddles outside of M. The only time I could really see it is if I want to engine brake, but this happens automatically if I touch the brakes while going downhill. I remember trying it during the test drive and being quite underwhelmed, but later I got to try M mode and was more pleased with the way it behaved.
The "S" mode behavior described above only applies to models that have shared transmissions with Toyota products, such as the ES.
At least, what you've described is the most useful purpose I see so far. Being about to find a lower gear quickly for passing or engine braking without switching to M mode.
However, the way Lexus describes this (and the way I interpret it), is that you are creating a "temporary shift range" as its named.
For example, if you put the car in M4, it will be in 4th gear period (unless you slow way down).
However, if you put the car in D4 (using paddle shifters while the shift lever is in the D position) than the car will shift normally through gears 1-4, but not exceed 4th. You've then set your "shift range" to gears 1-4.
That is how I understand it is "supposed" to work. They say after pressing the accelerator for an extended amount of time (4 seconds for me) than it disengages this function and returns to normal Drive mode.
So it seems only useful just to get you in that lower gear quickly and temporarily. But that's not a "temporary shift range" as they've called it.
Raghza (07-10-18)
I only use the paddles in D mode when I want to slow without touching the brake pedal. Other than that I find it useless as the computer will revert back to D mode pretty quickly.
Around traffic I keep it in M mode so I can move around more efficiently as the transmission takes way too long to react.
I come from 6MT, so I miss the shifting. I sometimes put into M mode and forget to shift up after red light and hit high rpm on 1st gear by accident. I'm going to try to exclusively drive on M mode going forward.
I wonder what long-term effects that will have. In M mode the torque converter gets locked up from 2nd to 6th gear.
The only thing I hate is how it feels like the car automatically shifts out of 1st and 2nd much sooner than you think/feel it should. Every other car I've owned would stay in gear when in Manual mode and just bounce of the rev limiter. I suppose this isn't a big deal, but it just feels like it shifts out of 1st and 2nd early.
Former5SFE (07-12-18)
