Seat position after/before switching on
There are 3 memory seat positions in my is300h
Can and how to make when shutting off before leaving and when entering before driving, to make the seat in a high position?
maybe using one memory?
it seems that the seat always returns to an unwanted position ( that what I want to change )
thanks
thanks
I dont have this in my car, but I believe there's an option under vehicle customization that will change that.
if not, the dealer can change it. Alternatively if you have techstream it can turn off that option too
ronnen (08-07-18)
There's an option under vehicle customization named "driver seat easy exit" or sth. There are 3 options - full, partial and off.
Full - the driver's seat moves all the way to the back and the steering wheel all the way up when the car is stopped and the seat belt unbuckled.
Partial - the driver's seat moves half way back and the steering wheel half way up
Off - neither the driver's seat or the steering wheel moves when the car is stopped and the seat belt unbuckled.
If the option is set to "full" or "partial", the driver's seat and the steering wheel will always move back to your last position when the ignition is turned on.
If you want to make the seat move higher, not backwards, then yes - just set everything the way you want to be and assign it to one of the memory buttons.
ronnen (08-07-18)
there's an option under vehicle customization named "driver seat easy exit" or sth. There are 3 options - full, partial and off.
off - neither the driver's seat or the steering wheel moves when the car is stopped and the seat belt unbuckled.
