Front Badge 5D LED
too tacky for me but here's a thread which you can go through to see where to grab this.... I think it's similar to what you want.
https://www.clublexus.com/forums/gs-...-logo-yet.html
The sellers website is listed in the comments.
NoTnoShade (08-09-18)
This is helpful, but I'm looking for LED or fiber optic to basically mimic that look of the Mercedes emblem (I think what is known as 5D). It won't be exact because Mercedes has a recess in the negative space of the emblem, but a thin enough (and flexible enough) fiber optic cable or LED should do the trick. If anyone hears of a pre-made product, let me know. Otherwise, I'll have to experiment myself. I'm hoping to connect it to a rocker switch that fits one of the blank buttons I have to the left of the steering wheel.
Something New
After searching and searching for a front logo 5D emblem, I found this:
https://ampdemblems.com/send-us-your-emblem
This option will allow us to install our circuit into your emblem with no worry on your part that you might not be capable of the process. Use this option also if you just would like us to do the work for you.
Select this option, if available, on the product page in our Online Store. After you place your order, mail us your emblem to:
Amp'd Emblems LLC
PO Box 8943
Jupiter, FL 33468
ampdemblems@gmail.com"
"Send Us Your Emblem
Our "Send Us Your Emblem" program allows customers to provide us with an emblem that they remove undamaged from their car, or purchase new from their local dealer or other source, that we then convert into an Amp'd Emblem®. We will convert your emblem into an Amp'd Emblem® with your choice of Amp'd Emblems® customizations.This option will allow us to install our circuit into your emblem with no worry on your part that you might not be capable of the process. Use this option also if you just would like us to do the work for you.
Amp'd Emblems LLC
PO Box 8943
Jupiter, FL 33468
