Hello everyone, I have a question since I'm new to Lexus, I did search but found nothing.
Are these yellow flares a normal thing on these LED headlights?
It is reflection off your floor tiles. Try on other surface
It does that in any surface, I had an accident a week after I got the car and I didn't notice this before, it seems like yellow flares shooting up everywhere.
Not too sure if this helps since I took it from inside of the garage, but here you go. I'll try to get another picture when I'm further away from the outside of the garage when I go out.
This helps, thanks! I can see the flares although I don't see any yellow.
I guess this is normal, I bought this car last month, I must be used to my former BMW's projector cut off.
Thanks for taking the time to do this!
My car's a 17 but should be fairly similar. Keep in mind that its not very easy to focus several sources of light with a single bowl. You'll get some scatter. Your bmw likely had xenons which was a single source for 1 bowl. With what i've seen so far on LEDs, I still prefer a proper set of xenon projectors than a LED setup. Brighter, wider, and much cleaner cutoff
Here is another picture with a more distant look... Mines looks similar to the post above ^
I hope these give you a better insight. Looks like the flare is not as bad as your picture, but you can decide since different angles can make the lighting scatter look different.
