Does the GSF/RCF Lower control arm bushings fit?
Old 01-11-19 | 01:08 PM
  #31
EvilJoker's Avatar
EvilJoker
Originally Posted by Sasnuke
$56.11 each USD - $112.22 total
Maybe there was a price change or a discount code use?
I found them on discount parts monster for $51 each https://www.discountpartsmonster.com...ket-4807524010
  #32
darkfire's Avatar
darkfire
Damn... must have been. I LITERALLY checked yesterday and they were cheaper.
Chris
Old 01-13-19 | 09:28 PM
  #33
AtomicAWD's Avatar
AtomicAWD
Thanks for the link, $114.45 shipped.
Looking to get these, along with mild springs. Are they just a straight parts upgrade, so might as well put them on at the same time, do alignment a few weeks later?
Old 01-13-19 | 09:40 PM
  #34
EvilJoker's Avatar
EvilJoker
Everyone says direct bolt in. Hope you realized that link was for one side only, and both sides are different. I ordered mine also.
Old 01-13-19 | 09:43 PM
  #35
AtomicAWD's Avatar
AtomicAWD
Yup, thanks. 75 and 76 -- be a bit of a bummer to get two the same!
Old 01-15-19 | 04:50 PM
  #36
sirdizzle's Avatar
sirdizzle
No modification needed to install on an IS350 (no idea about others). I had an alignment a few weeks after I installed them and the before specs were still in the green. You should be fine.
Old 01-25-19 | 10:49 AM
  #37
EvilJoker's Avatar
EvilJoker
Got mine put on this morning. Took him like 15min total. I thought you guys were full of crap about feeling a difference right away, but I can tell. The steering feels slightly "crisper" and you can feel a little more of the road feedback. I likey...
Old 01-25-19 | 11:45 AM
  #38
cliffhokie's Avatar
cliffhokie
How is vibration, especially steering wheel? I'm guessing zero since its not solid like RR?
Old 01-25-19 | 11:57 AM
  #39
EvilJoker's Avatar
EvilJoker
Its slightly more than stock. You get a little more road feedback, but definitely not annoying or uncomfortable in any way.
Old 01-25-19 | 12:24 PM
  #40
cliffhokie's Avatar
cliffhokie
Thanks. I switched bushings in a previous car and I hated the steering wheel vibration, especially while driving. IMO, it wasn't worth the trade off. However, that was with poly based bushings, similar to RR. I really need to find someone local that's done this to test drive.
Old 01-25-19 | 01:46 PM
  #41
EvilJoker's Avatar
EvilJoker
Yeah, poly can be rough. I had tons of money in my suspension on my Z28. Tubular everything I could get, and poly everywhere. It transfers a lot of vibration into everything. Handled like it was on rails though... lol
Pretty sure you wont be disappointed in the upgrade, especially what everyone says about the tire wear before the swap.
Old 01-26-19 | 02:33 AM
  #42
RageRacerM's Avatar
RageRacerM
@EvilJoker You say slightly crisper and a little more road feedback. It’s good that you noticed the difference right away cause I’m kind of at the limit of how my car feels numb and not communicative to me at speed. I’m not quite sure at times where the steering wheel is pointed and to me, those few degrees of steering input matter, especially on back roads. This is even while I’m in Sport+.
Not sure if I should jump to RR-Racing or jus the RCF/GSF bushings. I realize the pros and cons of both, but ehhhhh, the numbness and isolated feeling is scary at times. Leaning towards RR-Racing at the moment. Any suggestions?
Old 01-26-19 | 06:15 AM
  #43
Sasnuke's Avatar
Sasnuke
My suggestion: RCF/GSF bushings
Rationale: The RRRacing bushings have been available for some time. While those that have installed it have commented on the feedback from the steering and vehicle, for some this has been a negative situation. The RCF/GSF bushings have been a newly discovered direct swap and upgrade to the IS bushings, and there have been similar comments about the feedback of the steering and vehicle, but none have put them in a negative light yet. Considering the RCF/GSF bushings are roughly 25% the cost of the RRRacing bushings, the choice, IMO, is clear. I would install the RCF/GSF bushings, and if still not happy with the performance of the vehicle, then upgrade to the RRRacing bushings. The reality is one product is rubber, the other is poly, either material with it's own benefits and drawbacks. The poly will need periodic lubrication to stop any noise it may create, and the rubber will have a shelf life compared to the poly which will likely outlive our grandchildren. For road use the RCF/GSF bushings, once again IMO, is more than enough to correct the issues with the IS front suspension complaints.
The following 5 users liked this post by Sasnuke:
henrymc8 (01-26-19), hotsaw11 (01-26-19), Jbreezie (04-02-19), RageRacerM (01-26-19), wthrman2 (02-17-19)
Old 01-26-19 | 11:32 AM
  #44
Flash5's Avatar
Flash5
I’ve had the GSF/RCF bushings on for about 4 months and have been very satisfied and happy with the difference. Naturally I’m used to the feel now so I no longer feel a difference, but time will tell if my inner tire wear gets a little better.
Old 01-26-19 | 11:33 AM
  #45
MacroZed's Avatar
MacroZed
This is exactly why I replaced the bushings on my IS with the GSF/RCF units. The car felt vague at high speeds. Going around long bumpy sweepers at high speeds scared the hell out of me with the original bushings.
The first drive after the bushing swap was almost like night and day.....and if NVH has increased, I can't tell.
